Hood or trunk installation tip. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2012, 05:23 PM
When putting a hood or trunk on you want to put the lower bolt first, that way if you don't have to hold it's weight as the bottom bolt can be put in and then the hood will be resting on the top of the hinge while you put the upper bolt in. You could literally put one bolt on each side and walk away. I am not holding the lid to take this photo, all with a bolt started and not even tight.
You can see that on the other side the guy is putting the upper bolt in, you can see the difference. If you were to let go of the hood it would fold down over the hinge destroying it!
On an older car or truck that has a trunk or hood hinge sprung to hold the hood or trunk open this is a the way to go for sure. Being that is what I have done for years I just do all of them that way.
Old 09-22-2012, 12:51 AM
evolvo's Avatar
Heathen
Jeez, Brian.........There you go helping people again without even being asked a ? Knock it off, will ya
Old 09-22-2012, 05:24 AM
Sorry
Old 09-22-2012, 07:11 AM
Phaeton's Avatar
Wife and I just did that last night. Installed the trunk that is.
Old 09-22-2012, 10:44 AM
Is that what you call it? We call it making nookie.
Old 09-22-2012, 09:31 PM
novafreek6872's Avatar
Nova Guru
I've also found that a 3rd person running the bolts in while 2 people hold the hood in position makes life super easy! Only takes 2 minutes for the initial install, after that one person can do all the adjusting.
Air ratchet is a Godsend too, but I guess most people here have one of those too...
Andy
Old 09-23-2012, 11:32 AM
Or if it's a 1975 Cadillac hood, get FOUR people to hold the hood while you put the bolts in, no kidding!
Old 09-25-2012, 09:33 AM
put up or shut up
I usually aim to put in the lower bolt first but when you got no bolt in and are moving around the hood trying to line it up with the holes I just stick it into the hole that's most ready for a bolt, if that means the top than that means I just have to hold the bottom more steady til the bottom bolt grabs. I'd say it's just as important to use your shoulder and have your hands placed in the right locations when putting on a hood.
Tip of the day #28 Hood spring installation. MARTINSR Body - Exterior 23 11-16-2012 10:16 AM
Hood and trunk alignment tip, for you pros too! MARTINSR Body - Exterior 60 09-30-2012 08:28 AM
Tip of the day fishing wire thru a trunk lid or hood. MARTINSR Hotrodding Basics 17 03-23-2012 09:19 AM
Dashboard LED Installation Tip Houston54 Electrical 18 06-10-2008 05:43 PM
Model A Trunk Hinge Installation simk Body - Exterior 2 04-01-2008 08:04 AM
