Hoodless frame - Probably a dumb question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2004, 03:52 PM
New Member
This is probably a dumb question but I was wondering if it would be possible (practical) to have a hood with no frame, to save weight and time.
If I made a custom hood out of a couple layers of glass or even carbon/kevlar, hooked it up to the hood hinges and attached the latch, what would be the probablem with that?
It wouldn't rattle while driving because neither glass, carbon or kevlar flex.
The only things I can think of are:
1) It may goof the crumple zones
2) It would bust if someone sat on it
Neither of which I care about.
Old 01-18-2004, 04:00 PM
Wiki Edits: 49
Possible.... Yes
Practical.... Depends on the size of the hood. The bigger it is the harder it would be to make one and have it work with the stock hinges. In the mid to late 60's several of the muscle cars had fiberglass hoods that were kept on by pins with locks so that might be an option.
Centerline
Old 01-18-2004, 04:07 PM
poncho62's Avatar
Wiki Edits: 5
To see how practical a steel hood with no frame wold be, watch a NASCAR race. Those hoods are flopping all over the place. They are not made to be lifted too many times.
Fibre glass maybe OK.
Old 01-18-2004, 05:19 PM
New Member
I would probably use kevlar, because its MUCH stronger than fiberglass. Its on ebay all the time and isn't too expensive.
My hood is really small, my car is a crx.
What if I extended the hinges so that they spanned across a good portion of the hood and not just a couple inches?
Can you tell me some cars that had the pins and locks so I can take a look?
Old 01-18-2004, 06:03 PM
nightrain_rod's Avatar
Blue Oval Finatic
Sounds like a good idea.
If the pins and locks are what I think they're talking about,it's nothing but a pin mounted under the hood.You drill a hole in the hood so that the pin pokes through it when the hood is down.Then,you put a carter pin through the pin to keep the hood from coming up.Really,they're used for when you have to do some custom work,like a big block engine swap,and you have to move your radiator forward,thus you have to remove the hood latch.They have little protectors that you screw onto the hood to keep them from scratching your paint.
Good luck.
Nightrain
Old 01-21-2004, 09:42 AM
jwart's Avatar
glass support
have you looked at idea of making fiberglass suppport for your new hood. when laying up hood u can make cardboard for frame form it into u channel fitted to deck contours, cover with wax paper, glass over & create 90' lips for easy mounting, strip & laminate to deck. use this method of reinforcement alot on aircraft construction to save weight. watch your weight as pin mount & lift off for work might be best, as hinges may put too much pressure on deck to keep it in unsupported raised position. good luck jw art
Old 01-21-2004, 10:45 AM
I assume you are looking to make you own CF hood instead of buying one for $500?
Some areas of concern:
Glass or CF hood is going to be rigid, but not strong. Your hood latches / bolts are going to put a lot of stress on a small area of the hood.
It will rattle. I would look at removing all the existing latches and using 4 pins as discussed above to mount the hood ( 1 at each corner) and lifting the hood off the car when you need access.
Any of these materials may react to sunlight and UV.
Water and snow may cause you some grief.
Proceed with caution. Most CF hoods are for show and not necessarily practical for a daily driver.
clicky clicky
Old 01-21-2004, 02:46 PM
Thom Laybourne's Avatar
To what Degree
You can do it. Remember that the two pins where for a reason other than just good looks. Air flow will push up in the compartment and you are going forward more than backward. Thus the double FRONT PINS. So, maybe a front hinged hood? Air flow should work to help.
hr41pearl
Old 01-21-2004, 11:06 PM
New Member
As I mentioned above, I'm not going to use CF, I'm using Kevlar, which is much stronger than CF. I have only ever heard of one kevlar hood, which I saw on eBay for $1150 w/ 2 days left.
Also, I'm doing mega body remodelling, so the hood is going to have to be a custom rig, I will not be able to buy what I want.
CF hoods are rigid AND strong. You can stand on a CF hood. And I'm going to use Kevlar which is stronger yet.
You don't have to worry about UV with kevlar, and I'm painting it anyways.
If it is secured at the front center, and both back corners, and is made of a material that basically cannot flex, then how is it going to rattle?
Maybe if it did rattle I could put a suction cup or two at both front corners, to hold it in place when im driving.
Old 01-22-2004, 09:01 AM
HMMMM
Sounds like you have it all figured out. Not sure what you wanted help on. If you can, post a picture of it when you get done. Sounds like interesting stuff.
hr41pearl
