Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Garage - Tools
  #1
Old 03-04-2006, 12:07 AM
ONEGALONLY ONEGALONLY is offline
Hook Up Lincoln Square Wave Tig 175 Pro Welder
Hi Guys
Need To Know If I Should Use 6/2 (with Ground) Or 6/3 With Ground To Hook Up My Square Wave Tig 175 Pro Welder In My Garage And Maybe You Can Tell Me "why" Use That Particular Wire. Thanks Lenny
Old 03-14-2006, 07:08 PM
Twisted6's Avatar
Twisted6 Twisted6 is offline
re: Hook Up Lincoln Square Wave Tig 175 Pro Welder
6/3 with the ground is Better If Your talking a 220 line which I think you are.
Reason 2 hots 1 common and 1 ground. hope this helps.
Old 03-14-2006, 10:05 PM
johnnymopar's Avatar
johnnymopar johnnymopar is offline
Love your nails! You must be a Libra
if your welder is 230v then you will only need 2 hots and a ground.
check your manual to see how much your welder will draw. if it only draws 30 amps then you don't need #6 wire, you could get away with #10.
JB
Old 03-15-2006, 06:30 AM
Twisted6's Avatar
Opps brain Burrp on my part. You only have 3 prongs. what was i thinking sorry Been helping a friend install a bunch of driers & stoves lately for a few extra Buck and I guess I had four Prong Out lets on the Brain.
But johnnymopar is right.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Hook Up Lincoln Square Wave Tig 175 Pro Welder"
Good quality TIG welder which one?? sevt_chevelle Body - Exterior 8 01-05-2006 05:58 PM
Seeking used TIG welder rpaulsen Body - Exterior 3 02-03-2004 10:19 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
