hook up the lock-up on 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2008, 02:42 PM
Hi ALL!
I have an 85 Trans-am with a TH700 R4 trans , the LG4 ECM engine is gone swaped with a carbed 355 , I'm trying to hook up back a lock-up and don't have A SINGLE CLUE how to do it and the more I read the less I understand... So far I'm trying to say things in the most simple way . So far right now I have the wiring from the lock-up still in the trans, it's a 4 pin connecter that run out from the tranny going in the ECM harness that I was pulling out . Tracing this lock-up wiring shows me 3 wires: 1 is blue, 1 is pink and one is brown . My question is how could I hook back the lock up using those 3 wires if there's a way to do it so..! ????!! And I could not find any answer nowhere....
Your help would be highly appreciated!!
Old 02-25-2008, 03:31 PM
justold's Avatar
If you look in the knowledge base there are several articles on the subject , you do not want to operate a 700R4 without the lockup working , fluid is diverted from the cooling circuit to the lockup circuit to unlock the converter .
Old 02-25-2008, 07:48 PM
thanks but I've read about all.All that made me even more confused.. What I need is someone who could simply tell me how I should hook up those 3 wires I have to make this lock-up work . And moreover I need that explained in VERY SIMPLY words !!!!!
Old 02-25-2008, 09:04 PM
justold's Avatar
If you have three wires : purple - hot from brake light switch .
dark green : high gear switch [ not needed ]
tan / black - you want to put this wire to ground ,that's it .
When the transmission comes to temperature you will get lock up after 2/3 shift . MAKE SURE the TV cable is properly adjusted if not the transmission will not live long , check with a pressure gauge at both open and closed throttle .
Old 02-25-2008, 09:35 PM
thanks lot for your help!!!
OK, the wires maybe were a little dirty it looked like there were a pink, brown and blue. I'll clean them more to check the colour , so If I get you when pulling out the ECM harness left ,one of those 3 wires should be running to the brake switch behind the pedal?? and the 2 others free with one of them to ground and done??
Old 02-26-2008, 01:30 PM
is that what I exactely need to do?
http://www.700r4.com/tech/tcc/brake_.../diagram.shtml
Old 02-26-2008, 06:19 PM
66chevystepside's Avatar
Looks like the hookup you need.
Old 02-26-2008, 06:31 PM
31 five window
Last journal entry: grill and rear end
To the best of my knowledge that wiring diagram is for a kit not the stock set up. I think the kit is the only way to make it work without the ECM.The kits are available in Jeg's and Summit and are not hard to install.
Old 02-26-2008, 07:37 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The wire harness systems of the early 700 trans were complex , with pressure switches at each end of the v-body.
Hooking up 12 volts to 'hole A" and the grounding "hole D " may provide lock up of the converter in 2nd , 3rd and 4th gears...
GM did activate the converter clutch in 2 - 4th gears in the early days.
Pull the pan and see what is in there is the best option.
The wire diagram posted link , is the best way to wire up for lockup in OD only. IT is a dirt simple 12 volt system for the solenoid l/up of the converter. 12 volts in , a ground and a pressure switch... dirt simple
I receive many emails about the 700 lock up system and have yet found an easy way for folks to understand without photos as shown at the link listed.
Old 02-27-2008, 04:59 AM
I installed a simple toggle switch on my console in a 67 Camaro. I can lock and unlock the converter at the flip of a switch.
Old 02-27-2008, 01:49 PM
Warrant's Avatar
72 Nova, 65 Rambler, 37 Chevy
http://purplesagetradingpost.com/sum...o/700R4p1.html scroll to the bottem
http://www.73-87.com/7387garage/drivetrain/lockup.htm
Bowtie has good diagrams to as stated above, look around there, their is several
Old 02-27-2008, 06:40 PM
I think I have this link that gives a great answer in the mosty economical and simple way without oppening the tranny
http://www.clubhotrod.com/forums/tra...anny-swap.html,
at least works for me as my wires are the colour mentionned. Will try that on my car and see.
700r4 Lock up? cjoform Transmission - Rearend 3 12-21-2010 07:05 PM
How to hook up a 700r4 TV cable Linez35 Transmission - Rearend 7 10-21-2010 09:29 PM
700r4 hook-up Don Meyer Transmission - Rearend 2 10-18-2010 04:25 PM
700r4 How to hook up the reverse lights?? Wac Transmission - Rearend 5 01-08-2010 08:37 AM
th 700r4 lock-up jean-karim Transmission - Rearend 10 06-05-2008 05:44 PM
