hooking up a auto meter gas gauge? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2008, 11:01 PM
tiresmoke55's Avatar
PO-BOYS-TOYS!!
Last journal entry: My new 55 chevy pretty sharp
Quick question,, i have a new after market gas gauge and a 16 gallons fuel cell that has the sendind unit in it,,, what is the best way to wire it up?
any help would be great thanks
Old 05-03-2008, 06:30 AM
connect the wires together would be a start
Old 05-03-2008, 09:08 AM
The gauge and sending unit MUST match! Unless the unit came with the gauge or you have the specs for both you will need to check with the manufacturer of the gauge to see what it requires then check the sender. If you can not get the manufacturer specs on the unit you can check it with an ohm meter to see if it matches the gauge. Do this before hooking up anything and do not just hook up the wires and hope for the best. Do you have any info for the gauge?
Old 05-03-2008, 10:19 AM
PO-BOYS-TOYS!!
No i sure dont have any info for the gauge,, it came with the car, after i take a ohm meter, and if it checks out ok i was wondering on what wire went where, i have never messed with a after market fuel gauge before
thanks
Old 05-03-2008, 11:46 AM
IF, and that's only if, the gauge is one of Auto Meter's generic models then it will be 33 to 240 ohms range so check the the sender and see what it reads. If you ground the meter to the sender body and probe the terminal that the gauge wire attaches to you can then move the float by hand and watch the meter to see what it reads. Call Auto Meter, they have a service number at their web site or you can E-mail them, and they will help you identify which gauge you have. If the sender does not match then you simply need to buy a sender to match the gauge, the sender will be cheaper than a new gauge but unless they match it will not work. If both are generic no matter what brand then chances are they are 33 to 240 ohms.
Old 05-03-2008, 05:05 PM
boatbob2
fuel guage......
hi,NAPA sells a nice guage witha sending unit for about $45.00 total,i have a set of these in my truck and they are accurate.
Old 05-04-2008, 01:27 AM
malc's Avatar
Living At The Speed Of Life
This is for an AutoMeter Fuel level gauge part 3514.
0 Ohms empty, 90 Ohms full for most GM vehicles from ´65 to present.
Old 05-04-2008, 06:11 PM
PO-BOYS-TOYS!!
Thanks very much for that info,, this will help alot!
Old 05-04-2008, 06:12 PM
PO-BOYS-TOYS!!
If i cant get mine to work ill check into that thanks
Old 05-04-2008, 06:13 PM
PO-BOYS-TOYS!!
Ill check that just as soon as i get home thanks for that great info
Auto meter Wiring 78Z Electrical 7 09-02-2009 08:02 AM
using 20 gauge without gas Slickriffs Body - Exterior 9 10-19-2007 09:11 AM
Need help with fuel gauge Crazy-J Electrical 3 03-01-2005 12:46 PM
VDO Temp guage quit codybird Electrical 2 05-03-2004 04:22 AM
Gas Gauge street rodder 1937 Electrical 3 08-26-2003 11:43 AM
