Length wont matter. T or Y wont matter. Pressure inside a hydraulic circuit is equal on all sides throughout.
Some Ford trucks T the line right at the LF hose, for a production example. |
"A liquid cannot be condensed or compressed."
That property is why a liquid, in this case a liquid with certain properties, is used in a braking system. As stated above, the pressure remains the same regardless of direction or distance. |
Thanks, Tominator and Yesgo,
I didn't think it should matter because, as you say, a liquid can't be compressed, but I thought it might be a good idea to get another opinion. This is the first brake system I've put together other than a rear-brakes-only T-altered I built many years ago, and just wanted to be sure. Thanks again. |
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| What front hubs (brake drums) fit a 52 Ford pick-up | lakota | Suspension - Brakes - Steering | 3 | 12-27-2005 11:56 PM |
| front disc brake leaking | Lowgmc83 | Suspension - Brakes - Steering | 2 | 12-20-2003 08:48 AM |
| Replacing fuel and brake lines | adb2f | General Rodding Tech | 4 | 11-25-2003 09:29 AM |
| front brake diagram drum brakes | 72chevyelcamino | Suspension - Brakes - Steering | 0 | 10-28-2002 02:17 PM |
