hooking up HEI - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2004, 08:32 AM
stinky jinx's Avatar
Searching for horsepower
hooking up HEI
I am replacing my stock distributor and coil on a 72 el camino with an HEI unit. There is pink( or faded red) wire and a yellow wire on the positive side of the coil. There is a brown ground and a green tach wire along with a filter/condenser wire on the negative side. The HEI has a conector post that says "tach" and one that says "batt"......I was told to only put the red/pink wire on the positive side and not the yellow as it is a voltage restricter wire. Can anyone tell me what wires to put on and which wires to leave off. Please include all the wires I have listed.
Old 11-03-2004, 11:31 AM
302 Z28's Avatar
Get a volt meter and check the voltage of each wire with the key on. One of those wires is a resistor wire and that is NOT the one you want to use. The HEI distributor needs a 12 volt source. You can use the existing tach wire however.
Vince
Old 11-03-2004, 11:54 AM
What kind of a reading am I looking for on the resistor wire?
Old 11-03-2004, 01:08 PM
docvette's Avatar
Wiki Edits: 12
HEI
Doc here:
The wires you will need are :
Pink to the "Batt" terminal on the HEI
The Green from the Tach into the "TACH" Terminal...
Properly insulate and tie back the Yellow and brown.
BE SURE the pink wire supplies power not only during the "Run" selection on the ignition, but the "Start" position also...otherwise it won't start..Check with a meter set for 12 volts, or light probe while someone hits "start" Look for the light or meter to go out or go to zero...
If that occurs, find the wire going to the starter (probably brown) to the "S" terminal on the solenoid, and join that with the pink wire ...(secondary ignition)
Before you abandon the Yellow wire check to be sure it's not for the alternator or regulator or horn relay...If it's a resistance wire it will have 6 to 9 volts on it with the coil hooked up .. check before you take it apart...
Doc
PHOTO: HEI connections...
Name:	start system 75-79.jpg
Old 11-03-2004, 02:26 PM
Thanks Doc,
it sound like you nailed it...jinx
