Hooking up new CS Alternator???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2008, 03:46 PM
DeathRattle's Avatar
Some Punk Kid
OKay I bought myself a new pulley system from GMPP and I now have a very fancy alternator....the problem is I dont know how to hook it up.
It has the standard BAT terminal on back...I put that to the positive on the battery
And then I have a harness plug that has 4 all white wires. They are labeled on the connector itself not the wires.. They are labeled S, F, L, P
My question is how do I wire it up??....it came with NO INSTRUCTIONS!!
Old 09-09-2008, 04:03 PM
T-bucket23's Avatar
Wiki Edits: 26
Most of the connectors for the CS alternators are four wire but will only use two of them and the wiring is the same as the SI.
S = a heavy gauge wire to the battery supply (horn relay)
F = not used
L = a small gauge wire that comes from the idiot light and energizes the alternator
P = not used
Hope this helps
Chet
Old 09-09-2008, 05:48 PM
T-Bucket, Corvette, Mustang
Here is a link to an old thread that gives a little more detail on ways to hook the CS up depending on whether you have a warning light or running a voltmeter.
can't find alternator wiring info i need
Old 09-13-2008, 05:08 PM
Some Punk Kid
Thanks for the help guys...still havent hooked it up....raining like crazy past few days and the garage aint clean enough and the bikes aint going outside
Old 09-21-2008, 04:18 PM
Some Punk Kid
Just to follow up I got it hooked up...I read the other thread and used the F wire instead of the L wire. This baby works real nice....I can put everything on and the volts wont drop.
Thanks again for the help!
How do I wire a 3 wire alternator when I used to have a 1 wire alternator??? billsbird Electrical 7 09-05-2007 09:01 AM
another frustrating alternator problem darom Electrical 13 04-09-2006 11:09 AM
alternator wire hanging in mid air?! pcoghlan Electrical 11 03-21-2006 02:47 PM
Charging system info............... poncho62 Electrical 11 11-26-2005 08:53 PM
one wire / three wire, alternator hookup 65truck Electrical 1 10-24-2003 03:59 AM
