-   -   hooking up a non hei (http://www.hotrodders.com/forum/hooking-up-non-hei-44098.html)
red nitro 07-24-2004 03:22 PM
anybody tell me how to hook up a non hei quick, just want to get it fired up, a 350 in a 68 chevelle, Thank you !
docvette 07-24-2004 03:55 PM
Dist.
[color=yellow][size=2]Doc Here:pimp:
You need of course, a coil and resistor, hook your 12 volts on one side of the resistor, the other to the coil (-), then the other terminal (+)on the coil goes to the points and Condenser.
Be sure the points have a ground pigtail, (most do) from the points body to the advance plate, and the hot wire isn't hitting anything else.
Set the points about 17 , and make sure they open and close, and you should be all good.
Doc:pimp:
[/color][/size]
red nitro 07-24-2004 09:31 PM
Thanks doc, a few carb adjustments and she runs great. Thanks for the help ! ! ! !
