If your pcv hose is going to your intake, i'd personally move it to the lower front large pipe on the Q-jet. If the location on the manifold is closer to one runner than the others, you will delute one or two cylinders more than the rest with crankcase gas. If you use the center port on the carb, the gases will be more evenly dispersed to all the cylinders.
