Hooking up tach on a 6v system - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2005, 04:24 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
So I'm an idiot, I bought a 12v tach on sale but realized to late I have a 6v truck...will it work? Is there anything I can do to have the tach run on 12v's?
I dont wanna bring it back since I cant find any other 6v tachs and it was a good deal (4" tach for $15).
Mike
Old 08-24-2005, 05:17 PM
poncho62's Avatar
Wiki Edits: 5
I thought we went all through this last week...................
Chances are, you won't find a 6 volt tach anyways. Why not just keep it until you convert the truck to 12 volts.
Old 08-24-2005, 05:39 PM
Nightfire's Avatar
Young & Idealistic
Wiki Edits: 4
Yes we did go through all this, but that was for CB, I was hoping the tach didnt require THAT much juice and might be fine running on 6v's....guess not?
Mike
Old 08-24-2005, 08:22 PM
Wiki Edits: 31
Ya got a flat 6, and a 3spd crash box, it's no 1/4 mile monster so what good would the tach be. you just need a good ear to tell you when to shift. If your trying to time it with the rpm's ( basicly when it hits the optimal 800 at idle, and smooth idle ) , don't. ya can use a vac/ fuel pressure testor and just time it until you get the best vacume. If ya wanted to really have a tach, probably old jags and other forigne sports cars had 6 volt and tachs, VW bettles remained 6v until 1967, maby 1 of those had a tach. But for your case it is impracticle.
Old 08-24-2005, 10:04 PM
Nightfire's Avatar
Young & Idealistic
Wiki Edits: 4
I dont need a tach really, but I want one you know? My moms car doesnt have a tach and shifting is easy to do it by hearing, same with my truck, but I just want a tach.......and I found the solution. Found a battery that has split volts, one side 6v one side 12v
Mike
Old 08-25-2005, 08:44 PM
Wiki Edits: 31
Mike
Still won't work tho, it uses the ign system is still 6v, it in theroy will read half the RPM's you have. Hooking up a dual volt battery to the ign system through the tach, won't do anything because it reads basicly how many times it hits #1 I think, there is no connection through the battery, only the ign readings and ign system. you might think about a mech tach, if you are staying 6v, if not, wait until you switch to hook it up.
Old 08-26-2005, 02:00 AM
re hooking up a tach on a 6 volt system
I bought a 6 volt tach last year from Westberg Manu. in Sonoma CA phone no. 707 938 2121. Maybe they can solve your problem. stens47
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
Ignition system info................ poncho62 Electrical 18 10-11-2008 11:10 PM
Charging system info............... poncho62 Electrical 11 11-26-2005 09:53 PM
mustang tach wiring stang_steve Electrical 0 07-14-2004 08:28 PM
installing a tach on a DIS system Hollywooding General Rodding Tech 0 12-01-2003 11:58 AM
