Hooking up timing lite - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2009, 01:32 PM
The battery is in the trunk so can I attach the timing lite to the alternator for positivie and a ground to the motor or body? If not what would be the next best way to make work. Thanks.
Old 08-08-2009, 01:41 PM
71-78malibu's Avatar
Faster than the speed of stink
that should be fine
Old 08-08-2009, 03:04 PM
ericnova72's Avatar
More for Less Racer
Yes, its fine. Just be care full you don't short against a ground point when hooking to the alternator.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Low buck 355 sbc not running correctly, wanting to much timing. ForceFed86 Engine 67 04-13-2011 01:35 PM
sbc timing question 350pano Engine 8 05-15-2009 11:30 AM
Timing Timing Timing bigcountry1009 Hotrodding Basics 6 01-20-2009 06:47 PM
Ignition timing woes KNanthrup Engine 16 07-22-2007 10:18 PM
