Hookup fuel pressure regulator - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2013, 10:56 AM
I am using a small Holley carb on a mild 4.3L Chevy V-6 and have a nominally 50 PSI electric in-tank pump. There is no possability of a mechanical fuel pump --
I bought a fuel pressure regulator with two ports and a gauge. My questions are where to locate regulator (is near tank with short return better?), how to plumb it up (tee the inlet?), and how much pressure to set it for
Any help appreciated!
Old 05-19-2013, 12:28 PM
DoubleVision's Avatar
I mounted mine on the firewall behind the distributor. However you didn't mention which regulator you have. To make it work you'll need the Holley Bypass regulator.
fuel pressure regulator Wezz Engine 3 03-16-2013 09:28 PM
Fuel Pressure Regulator daveh Engine 2 02-15-2013 10:36 AM
Fuel Pressure Regulator bprumos Engine 4 10-23-2010 03:51 PM
V8 w/ carburetor + eletric fuel, runs too rich. Do I need a fuel pressure regulator? 5_speed Engine 17 10-25-2009 01:51 PM
Do I need a fuel pressure regulator? mattson70 Engine 17 07-01-2007 08:03 PM
