Hopping up a '73 SS454 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2006, 09:23 PM
smac's Avatar
What can be done to a 1973 SS454 El Camino to increase power over the pitiful 240 net HP as delivered. The car is a VGC unrestored original so I don't want to get too carried away, but I figure there has to be a bunch of HP hidden away in there.
Thanks,
Smac
Old 02-06-2006, 10:47 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
049 heads (milled for about 9:1 if required with your pistons)
+ Comp XE268 cam
+ Edelbrock Performer intake
+ Reworked Qjet
+ 2200-stall converter
+ 3.42 gears
+ headers
________________________
400+ hp and a slight tick at idle. I just did the same thing, but I used an XE262 cam (heavy car, stock converter) and I estimate my output at 380-390.
Double check before you go buying heads... you probably already have 049s on it. If you keep the stock 8.5:1 compression, I'd stick with the XE262 cam, but that should still get you in the neighborhood of 375 honest hp at the crank.
Old 02-07-2006, 05:25 AM
Hippie's Avatar
Last journal entry: HEI comparison.
+ Comp XE268 cam
+ Reworked Qjet
+ 3.42 gears
+ headers
I had a '74 454 that I was going to drop in a '76 GMC Sprint, I came up with almost the same combo except I was going to put a 200-4R and a 3.73 behind it. The camshafts in the mid-70's BBC's were awful and the intake manifolds weren't much better, a cam swap, intake manifold and headers will do wonders. One good thing, the '72-'74 passenger car ( including El Camino) had some of the best factory oval port heads you can get. Keep your stock Q-Jet and dial it in to the new combo and swap in an HEI with a curve kit and good aftermarket internals.
Old 02-07-2006, 08:59 PM
FiveFeezy's Avatar
Fishing poles in the hot rod!
I'd throw on a 750 vacuum secondaries Holley, 4150 or 4160. It made my 396 a lot faster off the line and on top. Probably uses more gas though.
Old 02-07-2006, 09:04 PM
Malibu73's Avatar
'68 Chevelle Malibu Sedan
I'd put a bigger cam than a XE268 in a 454BBC. How about a 292H Magnum?
Old 02-07-2006, 09:35 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
It all depends on the static compression ratio and squish. This is where some of you guys get into trouble, using too much cam for the c.r.
Old 02-08-2006, 05:12 AM
Hippie's Avatar
Second that! The 268XE is a good match for his stock piston/head configuration and his engine/chassis. '73 A-bodies aren't especially light. Also his 454 came with a 800cfm Q-Jet, properly tuned it will perform just as well as a 750 Holley on the street and give better mileage and low speed throttle response. In retrospect though I would probably run a Performer RPM with the spreadbore carb pad instead of the regular Performer for a 454 with the oval port heads. Although even a '69 or older factory cast iron intake would be an improvement over what came on it.
72 nova door panels to 73 doors... fireforsin Interior 2 02-18-2008 04:45 AM
My 73 Vette Story Intrigue Hotrodders' Lounge 13 01-11-2007 07:32 AM
Will a 390 fit or work in a 73 Mustang..... onebadmerc Engine 4 12-08-2005 09:57 AM
73 Dart Sport parts interchange? dadeeoo Electrical 0 04-12-2004 11:39 AM
Big block for my 73 Nova Hatchback? 73 Nova Guy Hotrodders' Lounge 7 02-26-2003 10:40 AM
