Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - horizonal/vertical metal cutting saw
Old 11-25-2011, 05:30 PM
rsfyj rsfyj is offline
Last journal entry: My Last Hot Rod
Clean it out
Don't damage the gasket on the cover if you do use a good gasket sealant Pulsating blade could be adjustments on the wheels etc or look to see if a bunch of teeth are missing on the blade. Hmm i use wheel bearing grease on my saw gear box and have never had a problem the worm travels slower than a wheel on a car using the same lube.
