Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - horizonal/vertical metal cutting saw
Old 11-25-2011, 06:07 PM
tcoop tcoop is offline
Originally Posted by rsfyj
Don't damage the gasket on the cover if you do use a good gasket sealant Pulsating blade could be adjustments on the wheels etc or look to see if a bunch of teeth are missing on the blade. Hmm i use wheel bearing grease on my saw gear box and have never had a problem the worm travels slower than a wheel on a car using the same lube.
I was able to save the gasket for the cover. Is there a seal that goes around the shaft that the pully connects too? I know the shaft goes through the gear box so I assume there is a seal. The oil that is in the box now is the same consistancy as wheel bearing grease but far more sticky. As I mentioned earlier, this stuff is as sticky or even worse than molasses.
