Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - horizonal/vertical metal cutting saw
Old 11-25-2011, 07:20 PM
rsfyj rsfyj is offline
Last journal entry: My Last Hot Rod
just change the lube dont tamper with the shafts etc
Change the blade learn how to adjust the rollers and guides etc,, TIP I always use the slowest cutting speed blades last a long time if you don't get in a hurry. try to always use blades that have 14 teeth per inch they last longer. Blades with ten teeth per inch need a wider cutting surface to last as long. I use strictly 14 teeth per inch blades. The same for saws all, and saber saws for metal. They outlast the others by a wide margin. You will break a few blades until you learn what you need. Have a great time very useful tool
