horizontal bandsaw motor problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2010, 04:15 PM
I have a bandsaw with a motor problem the switch was acting up I bypassed it when the motor would just hum but not turn but I can spin the pulley and it takes off and runs fine could the capacitator start be bad when the switch was acting up the motor made a clicking noise while running but wired direct it does'nt make the noise. any ideas thanks if it the capacitator good place to buy them???
Old 08-08-2010, 04:28 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
It is either the capacitor or the centrifugal switch. You can hear the centrifugal switch on some motors on start up.. It makes a clicking noise and then stops when the motor gets up to speed.
Old 08-08-2010, 04:37 PM
Bmacdona's Avatar
You should be able to pick up a start capacitor at any motor rebuild shop or a good electrical supply shop. Take the old one with you. Make sure that you short the contacts before trying to remove it, to avoid a potential shock.
Old 08-08-2010, 04:39 PM
njnnnnn
how do I short them?????
Old 08-08-2010, 04:45 PM
Bmacdona's Avatar
Just disconnect the wires and arc across the capacitor contacts with a plastic handled screwdriver, it'll eliminate any remaining charge (if any) in the capacitor.
Old 08-08-2010, 04:50 PM
mmmmmm
cool thanks
Old 08-08-2010, 05:40 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Could you be talking about this band saw or one like it, see picture. If so here is what I can tell you.
I used a friends before I bought the one pictured, and it did exactly as you described. I figured out that it was not the motor. Remove the belt an you will see it runs.
When I bought this saw I opened the gear box, brand new it had this mix of what looked like graphite and oil.. I mean gray slug like past. I literally had to scope the crap out, washed the box several times with lacquer thinner to remove the past. The second picture shows the update I made, along with redesigning the wheels so I could move the thing without it falling over, and some other little items to make cut true. It is a descent saw but does need some help to make it a worth while tool .
ID:	47254   Click image for larger version
ID:	47255   Click image for larger version
Old 08-08-2010, 06:40 PM
mmmm
similar but not the same but i will check it out thanks for the heads up
Old 08-11-2010, 03:27 PM
Silverback's Avatar
Boost Retard
I have an older green HF version of the same saw... I actually returned one for exactly that problem (and a cracked casting) and when the second one did it also I figured that I'd fix it...
swapping the gear lube for something less sludge like helps, especially if you're having this problem in the cold, but the real problem is that the stock start capacitors really suck. Replacing them with a new one should fix it, I just added a second one, so I have 2x the the original capacitance (probably more like 1-1/2 since I'm sure that the original didn't have what it was rated at), and now it starts with authority (it might be a little too much, even the stock little motor has enough torque at start up to flex the mounting/adjusting plate).
Old 08-19-2010, 11:43 AM
ttttttt
went today and got a capacitor the old one was small (china) they sold me a new one bigger and gave me a new cover for it (used) runs great now !!!! I noticed the bearings that guide the blade are getting bad they do not have brand name on them just 6000zz any idea where to find these metric I think
Old 08-19-2010, 12:13 PM
www.useenco.com
Just search "bearing" and follow the guide. Cheapest and easiest place I know to get decent bearings, I have bought a bunch of them from these guys in various sizes and I am sure they have the ones you need.
BTW, they can probably get you anything else you might need for that saw since they sell their own model of the same one.
If you decide to order from Enco they have a code right now that will get you totally free shipping if the order is $25 or more.
Old 08-19-2010, 01:12 PM
ttttt
Thanks for the tip enco has the bearings need to check on one more size I need then place order
Old 09-27-2010, 07:53 PM
Silverback's Avatar
Boost Retard
Check an auto parts supplier, or there are even "bearing houses" in most major cities. Almost all bearings are standard sizes that can be looked up by the numbers on the side of the bearing, and usually if I need one or 2 I just get them from a local store, if I need more I've bought them by the tube, 10 at a time on ebay.
Kalamazoo horizontal bandsaw C-10 Garage - Tools 10 05-16-2009 12:18 AM
Titan Industrial horizontal bandsaw sotxpanrider Garage - Tools 1 03-26-2005 06:57 PM
any ideas on switching a wood cutting bandsaw to metal jz29A Garage - Tools 2 02-21-2005 05:52 PM
driveshaft angles, what about horizontal angles catscan4free Transmission - Rearend 4 01-26-2004 06:23 PM
