Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Horizontal Radiator behind SBC with twin fans, but still overheats
Old 12-05-2011, 10:18 AM
406 bug's Avatar
406 bug 406 bug is offline
9.82 @ 139mph
Originally Posted by patentguy
Thanks everyone, always great advice here. I kept the radiator hooked up to the cooling system, but tilted one corner up until it was at the same level as the system cap mounted above the thermostat (see pic). I added fluid until it was flowing out of the bleeder valve on the radiator, closed it all up and ran the engine for a bit, let it cool and checked the coolant level again. It looks like I have all the air out of the system now and on several test runs the engine stayed at normal temp the entire time. The large truck radiator and twin 14" fans seem to be doing the job of cooling, but I guess my question now is will air accumulate in the radiator over time, creating the same situation I just fixed. The filler cap is the highest point in the system and I added a bleeder port to the top of the radiator end cap to bleed any accumulated air. If air is going to be problem, I will have to look at mounting the radiator upright somewhere else. I like the low profile look of where it's at but I need max cooling capacity. This is going to be a parade vehicle, so it is going to be idling on summer days. My other thought was to add a small vertical radiator with an electric fan at the front of the engine and run the heater hose ports to that secondary radiator.
It was great getting this silly thing running. It rides a little stiff, but it is very stable for something that looks top-heavy:
http://www.flickr.com/photos/kathyca...in/photostream
Great job on the Cart. Here is something you might want to consider. If you think about grocery carts and how shoppers load them up, you usually see the big bulky items on the bottom of the cart; this presents an ideal opportunity for you to screen the motor/drivetrain/radiator. Replicate a giant box of Tide or other large item for the bottom, along with a few items in the basket.
