Horn Button wiring,one,wire,two - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2006, 02:19 PM
fat40's Avatar
How is a one wire horn button hook up to work, I have a two wire horn button now and would like to install a new button but it is a one wire , I know on the two one of the wires is hot and one is ground. Is there a way to hook up the one and get it to work?
Fat40
Old 12-20-2006, 02:46 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Perhaps when mounted on a metal surface, the switch is grounded.
See if you can get continuity between the pin on the switch, and the mount, with the button depressed.
Old 12-20-2006, 05:27 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
To properly hook up a Stock type horn button, the Button Center wiper is on a "Riding Ground" at the horn ring..The Horn button is a Brush type device that contacts a lower copper ring in the Column, when the horn is depressed..That ring has a black wire that goes to the horn relay GROUND of the Coil.
If you are using a two wire button, One wire goes to hard ground, the other goes to the horn relay Coil GROUND .. No power is run through the horn button.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Replace existing horn w/ ooga horn? BobbyG-39 Electrical 14 11-03-2007 02:58 PM
Horn Button on Lecarra Steering Wheel djboen Electrical 2 05-22-2006 06:35 PM
Grant Horn Button Assemblies don't make sense jpd37 Interior 4 05-25-2005 12:19 PM
Looking need exploded view of 54 chevy horn button wy.miner Interior 2 03-24-2005 06:39 PM
How do I safely disconnect air bag to fix horn button? MadRabbit Electrical 4 03-08-2005 06:57 PM
