Horn problem- 72 malibu converted to a ss-454 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2010, 04:29 PM
Zee Zee is offline
Hello,
I havent been here in a while, not had time to work on the "beast". I cant figure out why my horn wont work on my 72 malibu convert to ss..I have installed the ss dash and wiring harness in side motor compartment and under-dash...have I missed the horn relay, does anybody know how the dash conversion affects the horn/relay...FYI before the dash conversion the horn did not work. If I power the horn wire at the inside motor compartment, the horn will blow..any help would be appreciated.
Old 11-28-2010, 04:42 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome back. have you traced the wires from the horn down to see if there was any problems there. Or could be the relay.
Cole
Old 11-28-2010, 05:24 PM
Zee Zee is offline
I dont think I have any problems in the steering or the push button..my problem is I converted the wiring harness to an ss dash which replaced all the wiring under the dash, and under the hood.. I dont see anything under there that resembles a horn relay..and what I see under the hood above the brake booster does not resemble a horn relay, does anybody have a pic of the horn relay and location..thanks
Old 11-28-2010, 05:36 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
this is the introduction forum.
post electrical questions in the electrical forum
Old 11-28-2010, 06:16 PM
eloc431962's Avatar
Wiki Edits: 37
Should be on the firewall above the booster from the factory on the 72 . Unless someone else removed it or re-located it.JMO
Pic of relay attached.
Cole
Old 11-28-2010, 06:18 PM
Zee Zee is offline
72 Chevelle horn problem
I have converted my 72 malibu dash to the ss style..my horn never worked, and now I want to know how to make it operate. When I power the wire under the hood at the firewall connection it will operate...It appears that everything under the steering wheel is ok. Where is the relay and what does it look like, will it be different from the malibu style after the conversion..any help will be appreciated
Old 11-28-2010, 06:22 PM
Zee Zee is offline
Absolutly awsome reply--I have heard that this relay can be repaired any suggestions, as it has also been said that they are hard to find.
eloc431962's Avatar
Wiki Edits: 37
Cole
Old 11-28-2010, 06:37 PM
eloc431962's Avatar
Wiki Edits: 37
If i remember correct the relay from a 72-73 nova is the same also. http://www.google.com/#q=where+to+bu...7204dc07534ddc .
Cole
Old 11-28-2010, 06:46 PM
eloc431962's Avatar
Wiki Edits: 37
If i remember correct the relay from a 72-73 nova is the same also. http://www.google.com/#q=where+to+bu...567&fp=1&cad=b .
Cole
Old 11-28-2010, 07:01 PM
Zee Zee is offline
At your suggestion, I just went and pulled this relay and took it apart, it is fried eggs and ham, will try to find replacement, thanks for the pic...I thought this was it originally but wasnt sure..Big Help
454 chevy electrical gauge problem carey Electrical 7 06-19-2010 08:48 AM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
72 camaro 454 headers 72 Z28 Engine 3 12-22-2003 05:13 PM
'72 Chevy SS Nova 654spd General Rodding Tech 1 02-06-2003 10:06 AM
454 with suspension question on my 72 72 Z28 Suspension - Brakes - Steering 2 12-14-2002 03:10 PM
