horn relay - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2003, 06:55 AM
New Member
Post horn relay
well i have a situation ,i am doing my 71 chevelle over from top to bottom , am putting back together now , after i got running ,i opened driver door and the horn relay up by the voltage reguleter started buzzing , when i close door it stops, i put old relay on and does same thing , just wondering if this ever happened to any one else, and if they figured it out , i don,t have any lights hooked up yet , rear or front , well thanks for any help ,,will
Old 05-07-2003, 08:47 AM
superrodder's Avatar
Post
YUP works like it's suppost to.that's the way the late 60's and early 70's door ajar buzzes workedwas inside the horn relay they put a buzzer,cause the horn buzzer gets power from the battery before it makes it to the fuse block.
Kinda annoying sound though,beeezzzzzzzzzzzzzzzzzzzz.
Old 05-07-2003, 01:46 PM
New Member
Post
thanks very much, thats a load of my mind , thuoght i had a short somewhere, thanks again,will
