Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Horrible bondo job..need help fixin plz
Old 02-10-2013, 11:34 AM
cruizin uncle bob cruizin uncle bob is offline
I say if your dead set on fixing, find a donor at a junkyard, cut or have them cut the rear qtr out for you, make sure they cut wider so you can fit, change the quarter, think after you remove the bondo you gonna find more damage than bondo should fix, course there are those out there that will cover up a multitude of sins with a gallon of filler which just ain't right.
