HORRIBLE grinding noise, no start - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 12-05-2013, 01:41 PM
Great news. Congrats!
  #32 (permalink)
Old 12-11-2013, 01:21 PM
clwhoops44's Avatar
As i said, the timing needed a LITTLE adjustment.......
Got me a new timing light and put it to work for the first time today.. engine was firing at 6 degrees AFTER top dead center. Dont know how I screwed it up that much when dropping the distributor in but I got her advanced to a true 12 degreed BTDC at idle. Took it out and got on it.. All my problems are solved. No more long cranking to start up.. one crank and vroommmm.
I guess this vouches for the importance of finding true tdc before dropping the distributor in. I had the heads off when I (thought I hit tdc), but i was all out of whack. 18 degrees out of whack.
Starter not engaging properly... Horrible grinding 84Z Engine 5 09-01-2007 07:30 PM
nasty grinding noise derek32303 Transmission - Rearend 3 07-21-2007 08:32 AM
aweful horrible noise killerformula Engine 9 05-02-2007 11:46 PM
New engine, horrible grinding sound....anyone want to make a bet TurboS10 Engine 23 10-31-2004 06:56 PM
Grinding noise yogunna123 Transmission - Rearend 0 09-30-2003 05:45 PM
