Horse power 300 to 400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2003, 11:15 AM
I have a 350 4 bolt main It's been bored 0.30 over Dish piston's with mild cam with 441 heads with 2.02 1.60 1.5 rocker radi. Edelbrock intake idle to 5,500 with 600cfm Edelbrock. With Accel H.E.I Ignition. With march pulley under drive .Factory cast crank .
What can I do to get 300 to 400 hosre's Or Is my set up close to 300 range.
Old 06-14-2003, 08:18 PM
Easy...A good home port and polish job to the heads and then a cam in the 230 degrees of duration area with a 110 degrees of overlap should give it some real guts. Then top off the engine with a RPM manifold or the likes and with low gears (you'll need them), then you can go new Z-28 hunting! Oh, I almost forgot, the first thing on your list (especially with factory heads) is to get David Vizards book, How to Hotrod Small Block Chevys on a Budget. Good luck
Old 06-14-2003, 08:29 PM
vortec heads , a speed pro 224 duration cam .450 / .460 cam , and speed pro flattop pistons. The 2.02 / 1.60 wont help if your cam is to small.
your definately in the 300 range -Will
Edit : Check this out. http://hotrod.com/techarticles/61998/
Old 06-15-2003, 01:25 AM
E.T. divided by $ spent= Speed
70nova,have someone DD2000 it for you.
I have a similar set up but with 1.94s and a EX262 cam and mine was DD2000'ed once at 315hp/365Tq and again at 325Hp/366Tq Always figure on about 10Hp less than these dyno programs say though.
With that vette cam from your other post I'd guess about 280-300hp
