horse power - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2004, 07:05 PM
erythnul's Avatar
horse power
does anyone know how many horses are under the hood of a ALL STOCK 67' mustang coupe with a 302
Old 08-09-2004, 07:18 PM
Jmark's Avatar
130? is my guess.
Old 08-09-2004, 07:21 PM
poncho62's Avatar
Wiki Edits: 5
Thought that the 67 still used the 289, not a 302.............correct me if I am wrong.
Old 08-09-2004, 07:23 PM
erythnul's Avatar
i guess they put a few 302 in the 67's
Old 08-09-2004, 07:55 PM
As far as I know only 289 for a small block in 67
Old 08-09-2004, 08:02 PM
5.0 freak's Avatar
67's never had a 302, only 289, and if it's the stock c-code 289 4.7L then it has 235 horse power with a 4v carb, coming stock out of the factory. 67's are also the first year of the resto mod mustangs.
James - The mustang Freak
Old 08-09-2004, 08:20 PM
If yours has a 302 in it then sombody put it there.
As said, 289's in those puppys.
Old 08-09-2004, 10:11 PM
mstngjoe's Avatar
The 302 came out in '68.
In '67 the 289 2V (C code) was rated from the factory at 200hp.
The 289 4V (A code) was rated at 225hp.
The 289HiPo (K code) was rated at 271hp.
All numbers are gross at the fly wheel.
Old 08-10-2004, 01:01 AM
erythnul's Avatar
ok
all i know is that my dad bought it and its a 67' and the side says 302 ...its a 2v ...my dad never even asked the guy any questions about the car
and whats a good exhaust system for my stang to.....its dual and i need some good headers under 150 bucks ...they dont have to be awesome just better then stock....
Old 08-10-2004, 05:58 AM
mstngjoe's Avatar
You can check www.summitracing.com for some Hedman headers.
Entry level header well under $200. Nothing fancy, but gets the job done.
You obviously would like to bump your performance up some. Consider a intake & carb change. Also, check to make sure you don't have "granny" gears out back.
If the Mustang is really a '67 and it has "302" emblems, someone has obviously changed the emblem. Doesn't mean they changed the engine too.
On the front drivers side of the block, just at where the heads attach, there is a flat machined surface approximately 1/4" X 3/4" that has a date code stamped in it. You may need to scrub off dirt/paint to read the numbers there. Will look something like "7C15". That is the assembly date of the engine. It's a better clue than the emblem on the side.
Old 08-12-2004, 04:25 PM
New Member
HP
2Barrell195, 4 Barrel-225 HP, 289 HiPo.- 271HP Eat the Cheeze
