horse power - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2006, 05:42 PM
horse power
I have a 350 4 bolt main bored 30 a 510 dur 530 lanati cam
12 to 1 top domed pistons 300 horse heads valved and seated for cam a weiand intake and a 750 eldebrock carb.
a hammer head crank a msd firing box and accel distributor accel distributor cap and accel wires
and the valves are chattering any suggestions.
Old 07-18-2006, 06:51 PM
valve chattering
Are you running racing gas? or at least fuel additive. If not it might be firing too soon. You are running alot of compression you need to run a hi octane gas. also if your doing all of this already try moving the timing. hope this will help Grim
Old 07-18-2006, 07:43 PM
cabowabo's Avatar
big Q
what size vavle spring
i hope you got some stout springs for that cam if not check the piston for holes from the vavles hitting the pop up pistons
Old 07-19-2006, 06:21 AM
nitro_baller4692's Avatar
floppers forever
how can you have 510* dur. when there is only 360* in a circle?
Old 07-19-2006, 08:36 AM
Are there 360* in a circle or 360° in a circle?
Old 07-19-2006, 08:45 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
What kind of fuel are you using? With a 12 to 1 compression ratio you will have pre-detonation if you do not mix or use the right fuel.
extra horse power carnell Engine 6 10-25-2003 09:19 PM
300 horse power 355 70 nova Engine 9 02-19-2003 11:38 AM
Horse power and Torque HELP PLEASE!!! 70 nova Engine 2 02-18-2003 10:57 PM
pulleys does it give horse power or torque 70 nova Engine 2 02-18-2003 10:59 AM
