horse power question?
i have a chevy 400 .030 over with flattop pistons with 882 chevy heads that were bowl blended and gasket matched with 76cc chambers. the cam is .488 intake .510 ex 234 in and 244 ex at .050 duration with a performer rpm intake can anyone tell me what the compression is and take a guess on the horsepower? the piston have 7cc valve cuts and the gasket is .038x4.200. thank you for any help -charlie
Once you know that you can go to this link to plug in the numbers and get your CR. http://www.csgnetwork.com/compcalc.html Beagle |
the block was decked and the pistons are .005 in. thank you
I come up with 10.0:1 CR.
Need more details such as weight of your car to take a guess at the Horsepower. There are various online dyno programs that can give you a good guess at horsepower. Try this one. http://www.speedwaybids.com/tech/ezonlinedyno.html |
Hey Charlie, what carb? Headers? What size? Through the mufflers or not? Manufacturer and # of the cam? Valve sizes?
im sorry. its a holley 750 dp, the headers are 1-3/4 though 2 chamber flowmaster mufflers, the cam is a edelbrook performer rpm hyd cam #7102, and the car weighs 3550 with me in it. thank you for any help -charlie
ok I put in all your specs on Desktop Dino 2000, I didn't know what kind of intake so I did both. ET's done with a weight of 3550
dual-plan, large tube headers with exhaust 465 HP at 6000-6500 451 TQ at 4500 ET 12.06 @ 111.7 single-plan, large tube headers with exhaust 508 HP at 6000-6500 471 TQ at 5000 ET 11.71 @ 115 dual-plan, large tube headers open 515 HP at 6500-7000 466 TQ at 5000 ET 11.65 @ 115.5 single plan, large tube headers open 556 HP at 6500-7000 483 TQ at 5000 ET 11.36 @ 118.5 |
Had a real similar setup in my 89 Camaro with 3:89 Gear back 15yrs ago.
With the iron heads you'll be mid to high 12's depending on your rear gear and stall converter. That RPM camshaft won't come alive till at least 3500rpm then it really pulls good. Lumpy idle ect. Tuned with one before.. not my cam choice for sure. If you went with a RPM as suggested above with 70cc chamber it'll help a TON! I know edelbrock has approx power with that cam/mnfld and heads. Look in their catalog. With the right stall and gear and tune it'll go 11's. Mine was 11.6 to 11.7's on the motor and mid 10's on 150hp. Now I'm down 2cyl and run 10.3's @ 133mph on 93oct on Drag radials and get 20mpg!!! Nothing like a Buick Turbo V6! ![]() Good luck with the build, Scott~ |
| MII Power Steering question | v8muscle | Suspension - Brakes - Steering | 0 | 07-16-2008 01:40 PM |
| Power Steering question | Rick P. | Suspension - Brakes - Steering | 11 | 04-21-2008 01:17 AM |
| AC and Power Steering Line Question ??? | windsor8 | General Rodding Tech | 2 | 03-27-2008 09:02 PM |
| Another Power Valve Question | Blazin72 | Engine | 8 | 05-24-2006 10:44 PM |
| Power Steering Set-Up Question | jsrail | Suspension - Brakes - Steering | 3 | 10-16-2005 09:23 AM |
