Horse power and Torque HELP PLEASE!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2003, 02:25 PM
Post Horse power and Torque HELP PLEASE!!!
ME again. What horse power or torque will elebrock 600 carb with performatice 1500to 6500 intake with elebrock fuel pump with cam 488lift with 234 duration with 350 trans with 3.08 ratio will it help to have 3.42 ratio and been bord 30 over with March racing pulleys with 76 cc chambers heads with 161cc intake runners with1.94 /1.50 valves The numbers on the block is 3970010 and vo622tkf it a 4 bolt main . The engine factory had 255 horse power. PLEASE HELP I WOULD APPRIATE IT VERY MUCH!!!!!!!!!
Old 02-18-2003, 04:23 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Post
Low end torque will suffer a bit with the cam and intake choice. Go with the RPM intake and a slightly smaller cam.
Old 02-18-2003, 10:57 PM
Post
You'll need at least a 2500 stall if that 234 duration is at .050.
