Horsepower? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2014, 12:10 AM
MalibuMike's Avatar
Horsepower?
Can somebody tell me how much horsepower I can expect out of a 454 w/119cc heads,43cc forged dome pistons, and a 4.000" stroke
Old 02-05-2014, 12:14 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Need more information, cam specs, c.r., exhaust system, ignition, carb and intake. All you're sharing here is a bare block with pistons in it.
Semper Fi
Old 02-05-2014, 01:34 AM
MalibuMike's Avatar
Forged 48cc Dome Pistons
Edelbrock Performer 2-0 Intake Manifold*
Edelbrock Performer 750cfm Carburetor*
Edelbrock Performer-Plus Hydraulic Flat Tappet Camshaft .500''/.500'' Lift292/302 Adv. DurationIdle-5500 RPM Range*
& 119 oval port heads
Old 02-05-2014, 09:37 AM
vinniekq2's Avatar
I doubt it would run on pump fuel.wrong intake,carb too small.
Is this a test of an imaginary engine?
Old 02-05-2014, 03:31 PM
MalibuMike's Avatar
It's an actual engine I'm trying to put together & get about 400+ hp out of without redoing the bottom half. This is one scenario I was wondering would work by using high compression pistons. Any suggestions?
Old 02-05-2014, 03:55 PM
vinniekq2's Avatar
for perspective purposes;
an LS-1 is a well thought out fuel injected,roller cam 350 that makes 345 horse power.
you want to take an old generation 1 350 ,toss on a few random parts and make 400 horse power?
you need to use better parts than found on an LS-1.
Old 02-05-2014, 07:58 PM
MalibuMike's Avatar
Not a 350 a 454
Old 02-05-2014, 08:45 PM
vinniekq2's Avatar
9.5:1 cr/.550 lift roller hydraulic short duration wide lobe displacement angle,"rpm" intake,850 CFM carb,headers,clean up the stock heads(which heads do you have?if peanut port? not as good as almost everything else)
Old 02-05-2014, 10:42 PM
Greg T's Avatar
www.krusinklassics.net
Never gonna use that Ede cam with 12:1 CR. Aint gonna happen.
Old 02-05-2014, 10:49 PM
MalibuMike's Avatar
I have the 781 heads
Old 02-05-2014, 11:10 PM
vinniekq2's Avatar
781s,punch them out to 2.19/1.88 valves and a little clean up and hang on,,,,it will produce 400 hp with a plug wire off
Old 02-06-2014, 01:40 AM
MalibuMike's Avatar
What about the pistons,leave them stock? I was gonna go with .060 dome pistons
Old 02-06-2014, 02:48 AM
MalibuMike's Avatar
I just found some .060 over pistons with a 25.7cc dome that says their 9.61:1cr w/119cc heads... Could I use this setup with a .550 lift cam & get 400 or better hp?
Old 02-06-2014, 07:58 AM
vinniekq2's Avatar
you ave to varify piston domes and combustion chamber volume yourself,it has to be measured.You will have more than 400 hp if you follow what I said
The Following User Says Thank You to vinniekq2 For This Useful Post:
MalibuMike (02-06-2014)
how much horsepower chevyshortwide82 Introduce Yourself 2 09-04-2007 07:43 PM
how much horsepower kingj Engine 1 12-12-2005 03:48 PM
You Might Have To Much Horsepower If ... Ghetto Jet Hotrodders' Lounge 4 06-22-2004 12:33 AM
Horsepower Help M@MRACING Hotrodding Basics 1 06-03-2004 10:46 AM
Horsepower.... and horsepower loss PonchoTA79400 Engine 3 03-13-2004 09:25 AM
