horsepower?? any guesses - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2009, 01:12 AM
i have a 327 that is bored .030. all that is done to it as of now is it has a performer carb 600 cfm, and a voodoo cam. anybody wanna take a guess to how much power im making??
Old 01-06-2009, 01:18 AM
327NUT's Avatar
Well with that little bit of info there's no way to even make an educated guess. How about cam spec's, compression etc???
Old 01-06-2009, 01:29 AM
dinger's Avatar
I guess 112 h.p. on nitrous.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
yea i kno wut your saying, i just got the motor from a guy and dropped it in my cutlass so i haven't really got much more than that yet. just got it running late this afternoon. the guy i got it from wasn't a lot of help either.i put the cam in it has .560 lift and a duration of 243/251. other than that everything else seems stock internally. but like i said im goin to find out more about it just takes time. this is my first time trying to build my own motor so this is pretty much my toy.
Old 01-06-2009, 06:25 AM
bondo's Avatar
Ayuh,...
With that Monster Cam in a Stock motor,...
That hp# looks Awlfully Optimistic...
Old 01-06-2009, 07:37 AM
The Maintenance Geek
Originally Posted by bondo
Ayuh,...
Yup, I'll agree. First thing I'd change is that cam to something with less duration...
K
Old 01-06-2009, 11:55 AM
If you like the way it drives, what difference does it make?
Old 01-06-2009, 01:06 PM
yea your right but im going to be doing a lot of work to this motor and was tryin to get an idea of what i started with so i know when i finish it. but thinks guys
Old 01-06-2009, 01:11 PM
WINNER!!!!! That's the right answer.
Old 01-06-2009, 02:37 PM
techinspector1's Avatar
Wiki Edits: 326
"i put the cam in it has .560 lift and a duration of 243/251."
Son, you've made one of the most common rookie mistakes with your cam selection. The camshaft itself does not dictate the power made in a motor. It is just one part that must be matched with all the other parts in the motor to do a good job at whatever it is you want the motor to do.
To do its job correctly, that cam will need a static compression ratio of somewhere between 10.5:1 and 12.0:1 and will make power from 3500 to 7000 rpm's.
Without the proper parts and pieces to support this camshaft, you can expect the car to be slower than it would be with a stock motor.
Old 01-06-2009, 03:10 PM
302 Z28's Avatar
Sad fact, but very true. How many times have we heard a grond pounding thumper with a radical cam that cannot pull itself off dead center? Sounds bad to the bone, but it's a real DOG.
Vince
Old 01-06-2009, 03:19 PM
Yep. I've seen it 10,000 times. Someone, got bad internet advice. A cam will give the motor personality, but will not determine power.
Most annoying comment ever in my book "THOSE HEADS MAKE SOME POWER!" shut up....
Old 03-24-2009, 09:32 PM
my first cam was a summit cam 234 244 488 510 with 1.94 1.60 fulie heads preformer rpm flat tops and a 600 cfm holley and it was still to big that was on a 355 IMO anyway
Horsepower Claims Morgan22 Engine 26 10-18-2008 10:24 PM
Horsepower & Performance Formulas/Calculators edge General Rodding Tech 7 08-13-2005 06:01 AM
???the 411 on HP now & then ??? Rob Keller General Rodding Tech 20 07-13-2005 06:00 AM
Horsepower.... and horsepower loss PonchoTA79400 Engine 3 03-13-2004 09:25 AM
Horsepower then and now SteveW Engine 4 09-01-2003 07:10 PM
