The other part of this also is,in racing that is,is once you have the horsepower,then you have to get it to the ground,and keep it there,we had an engine tech,a chassis tech,a tire tech,,,all of these things have to be applied to shave a tenth of a second off your time.You can have a 1000 horsepower,but if you don't have everytrhing else dialed in,,,so what???I admit,,it's great to be able to say you have all of that power at your command,but it has to be directed.My little S-10 has around 450-500 HP,,and that's on a budget,but what I have it tied to at the momment doesn't do it justice.I know that my next improvement is going to have to be the gears and the tranny,until I get these things straightened out,,,all it is,,,is just a good street rod and not a competitive race machine,,but all in good time.I'm still having fun with it.
If you're talking about a ford windsor, or a small block chevy, or a mopar LA, then you have to consider that they are ancient designs that were last updated in the mid 90s. Updated heads on an engine architecture that was created in the 50's is one thing.
But, then when you see a 6.0L LS7 that makes 505 hp from the factory, passes rigid ARB emissions standards with no EGR, and returns 25-30 mpg with a silky smooth idle, that's a whole different ball game. Comparing a 302 windsor to something that is produced today is like comparing a flathead to a muscle car motor. It all depends on what has been designed for the engine to update it. I'm currently looking at spending thousands of dollars updating my 96 LT1 to a 383 stroker, CNC ported heads, a modern cam, and a ported intake. I'll be barely squeaking by the 12-year old easy smog test with 400-ish HP. I could also just drop in an LS1 with a couple bolt ons and get that same power that passes more stringent emissions tests almost transparently. Technology really has come that far. |
100 foot pounds and 4,000 rpm = 76.16 Hp Feed that through a 4:1 (zero loss) gearbox and you get 400 foot pounds and 1,000 rpm = 76.16 Hp I am not even going to ask how engine power varies with vehicle weight. |
Not only has the power just about doubled, but the weight of the engine has dropped by around a third as well. If it is going into a very light weight body, the engine weight drop is almost as significant as the power increase. |
sam-missle |
Then why did he post this?
[/QUOTE]Why would you want to do that ???? A dyno measures rpm and torque, and calculates horsepower. That is all it does. Vehicle weight and gear ratios have absolutely nothing to do with measuring horsepower.[QUOTE] Last edited by carsavvycook; 10-18-2008 at 09:48 PM. |
You measure engine power on a dynamometer. Vehicle weight has absolutely nothing to do with how much power the engine can produce. In fact you can measure engine power without even having a vehicle.
You measure vehicle weight on a set of scales. A vehicle weighs what it weighs, regardless of what type of engine it has. It may even have no engine at all, So you have a power measurement And you have a weight measurement The final performance of the vehicle depends on both. But both are quite independent. Does that help ? |
But (I still believe) the weight/gearing ratios requior more HP to move more 'mass' down the road. I am not 'sold' yet on your theory.
Sure, more power is required to move more mass (at the same rate) no argument from me there.
That is why power to weight ratio is probably the most important factor in estimating performance. |
| Horsepower & Performance Formulas/Calculators | edge | General Rodding Tech | 7 | 08-13-2005 06:01 AM |
| ???the 411 on HP now & then ??? | Rob Keller | General Rodding Tech | 20 | 07-13-2005 06:00 AM |
| Why I love horsepower. | coldknock | Hotrodders' Lounge | 21 | 05-27-2005 11:35 AM |
| Horsepower.... and horsepower loss | PonchoTA79400 | Engine | 3 | 03-13-2004 09:25 AM |
| Horsepower then and now | SteveW | Engine | 4 | 09-01-2003 07:10 PM |
