Horsepower estimate - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2008, 12:34 PM
Horsepower estimate
Hi All,
I have a 355 sb w/flat top pistons running 10:1 compression, 327 double humps w/2.02 int. 1.60 ext., a 260/260 @ .050 .555/.555 solid lift comp cam, a tr1x tunnel ram intake and a Holley 750 double pumper. With this combo what is your estimate of horsepower to the flywheel?
Old 08-08-2008, 03:38 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Information needed
block & cr:
355 10:1
heads low performance
#1 stock ports & valves, #2 pocket porting, #3 ported w/large valves #_____
#1 wedge heads stock ports & valves
#2 wedge heads pocket porting stock valve size
#3 wedge heads pocket porting large valves #____
induction manifold type
flow 750cfm tunnel ram
exhaust
#1 stock manifolds & mufflers
#2 HP " "
#3 small tube headers w/mufflers
#4 " " " open exhaust
#5 large tube headers w/mufflers
#6 " " " open exhaust
#7large tube stepped #_____
camshaft type
#1 stock street/ economy profile, #2 HP street profile, #3 Dual purpose street/track profile, #4 Drag race/circle track profile,
#5 Drag race high speed, #____
lifters, #1 Hydraulic flat tappet, #2 solid FT,#3 Roller, Hyd or solid #_____
cam specs @ 0.050
int.lift @ valve______ exh lift @ valve____
ivo (btdc) _______ ivc (abdc ____
evo (bbdc) _____ evc (atdc ____
ica (atdc _______ eca (btdc ____
Old 08-08-2008, 04:17 PM
Information needed
block & cr:
355 10:1
stock ports & 2.02 int. 1.60 ext.valves
exhaust
small tube headers w/open exhaust
camshaft type
lifters, solid FT,
cam specs @ 0.050
.260/.260 .555/.555
Old 08-08-2008, 04:39 PM
SSedan64's Avatar
Rich here's a link to the cams specs he has.
http://www.compcams.com/Cam_Specs/Ca...?csid=222&sb=0
Old 08-08-2008, 05:01 PM
SSedan64,
Thank you for the link, couldn't have don it without the other
specs, Thanks again, Rich
350sbrookie,
Torque 417 @ 5000 &5500 Power 479 @ 7000
Last edited by richard stewart 3rd; 08-08-2008 at 05:13 PM. Reason: put in wrong values
Horsepower estimate jakejake1966 Engine 39 03-15-2006 02:01 PM
Horsepower Estimate For A Smallblock 350 HJCHEVY400 Hotrodding Basics 14 03-09-2006 10:44 PM
327 horsepower estimate 1 Day Engine 5 02-11-2006 07:07 PM
Horsepower / Torque estimate? StevenC Engine 1 01-04-2006 07:44 PM
350Chev- Can anyone help on a horsepower estimate? for SBCDOWNUNDER Engine 3 06-24-2003 04:06 PM
