Horsepower Estimate - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2006, 03:26 PM
62chevystepside's Avatar
New Member
Horsepower Estimate
Just wondering how much I will be making once i finish putting it together, putting it in a 81 monte carlo,
1972 350 030
Heads 2.02
SPEED-PRO FLAT TOP COATED PISTONS
MOLY RINGS
CLEVITE 77 ROD BEARINGS
MELLING HIGH VOLUME OIL PUMP
CAMSHAFT 214/224 .445 .465 112
DUAL ROW THREE-KEY TIMING KIT
HYD VALVE SPRINGS (1.250 OD 110# @ 1.700 300# @1.250 .500 LIFT)
accel hei ignition and wires
performer rpm airgap intake
flowtech headers
750 edelbrock carb
Old 04-24-2006, 03:46 PM
How fast is fast enough?
ok, this is just a guess, and a lot of people will say its too high because of the ehads, but I'm going with about 360 hp at the flywheel.
Old 04-24-2006, 04:37 PM
Wiki Edits: 31
if ya can give me the compression ratio, I'll run the # for ya.
Old 04-24-2006, 04:57 PM
I would say 310hp. You really need to get rid of those stock heads!
Check out this site. http://www.ryanscarpage.50megs.com/
A lot of sbc dyno's on this site. Sorry, the low hp dynos run have the stock heads.
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
If those are stock heads you're looking at about 8:1 compression and some very marginal flow numbers. You'll be lucky to get 280 horse, and the RPM is probably not the best choice to match the powerband of that cam.
K
Old 04-25-2006, 12:14 AM
New Member
what kind of intake do i get, for it, what kind of heads should i get, im kinda on a budget. What will be the difference in the power if i get new aluminum heads.
Old 04-25-2006, 01:35 PM
50 hp difference most likely. check out that site I listed above. You don't need alum. heads. A set of Darts or Sportsman II's will also work well.
Old 04-25-2006, 02:16 PM
Dart Iron Eagle all the way!
Horsepower estimate jakejake1966 Engine 39 03-15-2006 02:01 PM
Horsepower Estimate For A Smallblock 350 HJCHEVY400 Hotrodding Basics 14 03-09-2006 10:44 PM
Horsepower / Torque estimate? StevenC Engine 1 01-04-2006 07:44 PM
Horsepower estimate Thacolbster Engine 7 09-07-2003 02:23 PM
350Chev- Can anyone help on a horsepower estimate? for SBCDOWNUNDER Engine 3 06-24-2003 04:06 PM
