Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - horsepower guesses?
  #161 (permalink)
Old 04-01-2011, 04:04 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Sounds about right for a cam of that size, its not going to make a ton of vacuum like a stock cam or street performance cam will.
The tube needed for the dipstick guide is a piece of 5/16" fuel/brake line, about 6-1/2" ling. Buy a 12" stick, cut it at 6-1/2"and keep the flare at one end, discard both nuts, and drop into the dipstick hole flared end up. Then install the upper dipstick tub as you normally would.
