Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - horsepower guesses?
  #205 (permalink)
Old 02-19-2012, 10:53 AM
abigassbowtie abigassbowtie is offline
well the reason i didnt post after running it with the new springs is cause i was pist off cause it threw a rod at the end of the track im looking at some options and would like to hear some opinions I have 2500$ and would like it to not cost over that
turn key ls 5.3 tuned to 325hp
start all over with a 496 I have a 427 t with a bent push rod and I have some ok oval port heads that would need alot of porting and bigger 2.250 valves or buy pro comp aluminum heads and a solid flat tappet cam with 10-1 compression
or build a new short block for the 406
