Could someone guesstimate the hp/tq of this setup,
350 small block 3970014 Stock crank L2304 0.100" 030 dome pistons (forged aluminum with forged Aluminum rods) Comp cam xe262 cam and lifter kit Camelhump 462 heads 2:02 /1:64? Edelbrock performer intake Quadrajet carb Stock hei distributor 3speed auto tranny 3;42 rear gears 1981 camaro gutted completely Thanks just a ball park would be appreciated |
need some suggestion on spark plugs and gap to run in my combo i have been running autolites and wanna make sure what ever i get is correct and i would like to set them up with correct gap since i never did that in the past
thanks for the help |
got my new tires on and got my plugs in and changed to a stock hei distributor because my pos msd was full of oil so i went to check the oil and something has been hitting the dipstick and broke it off so out comes the motor so while im at it im gonna change head gaskets and try to figure out if i had originally put in a broken spark plug or if something hit the prong on the #4 cylinder plugs looked really good other than that one
this motor is pissing me off Im about to put my 396 in it for this year at the drags Last edited by abigassbowtie; 03-18-2011 at 02:51 PM. |
It goes in the dipstick hole first, before the upper tube is pressed in. The lower tube guides the stick down into the pan and keeps it from coming into contact with the spinning crank. Without the lower tube the crank will hit the stick and break it off on the lower end. |
well that is what happend then cause i put the dipstick in and did not install a lower tube guess i know what happend that is some what of a relief
I wonder if i could get it out with out pulling the motor? |
Right on the full line is a common breakage point, because the stamped line makes a natural fracture/fatigue point. So that leaves about a 1-1/2" long piece in the pan.
Maybe you could fish it out with a pencil magnet through the drain plug?? Or put a magnet on the bottom of the pan to "capture" it and just leave it there until some point down the road that you have the engine out or the pan off?? |
| horsepower?? any guesses | 327supreme | Hotrodding Basics | 12 | 03-24-2009 09:32 PM |
| Build for Hp or Torque? | Venturat | Engine | 76 | 09-23-2008 10:22 AM |
| Horsepower & Performance Formulas/Calculators | edge | General Rodding Tech | 7 | 08-13-2005 06:01 AM |
| ???the 411 on HP now & then ??? | Rob Keller | General Rodding Tech | 20 | 07-13-2005 06:00 AM |
| Horsepower.... and horsepower loss | PonchoTA79400 | Engine | 3 | 03-13-2004 09:25 AM |
