well i took it out friday and it didnt do what i was hoping but i only got to make one pass before i broke an axle shaft on the launce
i ran a 1.9 60 foot and ran a 13.21 @101mph I know it has more to come it is running smoother and better than ever but i need to play with timing and stuff i had adjusted it to 36* when it broke the shaft we will see in a week or two how it does when i get new axles eric: where do you get your custom axle shafts in 35 spline chromolly? |
My Nova has Dutchman's in it, found them cheap on Ebay when someone was upgrading to a larger axle. Everything else I've done has had Moser as they are only about 150 miles from me.
A friend has used Superior without problems, but I think they are just stock dimension replacements. |
yeah dutcman is only 250 miles from me in fact if it werent for me wanting to race this coming weekend i would have saved the 30 dollars shipping cause im going up to portland for a psca race on the 11th
when i oredered my axle shafts they informed me that my bearing journal was an odd ball size at 1.625 they rarely see so they suggested that i change that to 1.531 so my new bearing part number is 514003
bearing dimension is 1.531 id by 3.150 od |
i shaved maybe another 100 lbs off of the truck and let a friend drive it down the track once and he ran a 13.1@103 i really think that it needs bigger headers
but i dont know why the hell i cant get the 106.3 mph again i think this thing should be running 110 mph |
well i think i figured out why my mph is so low I pulled a few valve springs off and checked them and they are 130 lbs @1.900" so time for new valve springs im looking at the k-motion #k-1100 ! think those will be good? man i hope this thing picks up 10 mph
well the reason i didnt post after running it with the new springs is cause i was pist off cause it threw a rod at the end of the track im looking at some options and would like to hear some opinions I have 2500$ and would like it to not cost over that
turn key ls 5.3 tuned to 325hp start all over with a 496 I have a 427 t with a bent push rod and I have some ok oval port heads that would need alot of porting and bigger 2.250 valves or buy pro comp aluminum heads and a solid flat tappet cam with 10-1 compression or build a new short block for the 406 |
well i got a 76 chevy truck with a good running stock 509 400 block Im thinking about throwing my whole top end on it and seeing what it does i know its gonna lose alot of compression but its something i could have going by june
any thoughts |
well i parted out that motor started to build a 496 and got sidetracked when I found this nova for sale I drove it home for 1500 straight six and a glide
![]() heres the parts car i bought for 1k ![]() and here they are getting parts swapped ![]()
i got the weld wheels and tires the 8.2 ten bolt 5 lug and a disk brake 5 lug front end another set of v8 motor mounts and a nova oil pan and a bunch of random little parts the yellow car is pretty rusty
| horsepower?? any guesses | 327supreme | Hotrodding Basics | 12 | 03-24-2009 09:32 PM |
| Build for Hp or Torque? | Venturat | Engine | 76 | 09-23-2008 10:22 AM |
| Horsepower & Performance Formulas/Calculators | edge | General Rodding Tech | 7 | 08-13-2005 06:01 AM |
| ???the 411 on HP now & then ??? | Rob Keller | General Rodding Tech | 20 | 07-13-2005 06:00 AM |
| Horsepower.... and horsepower loss | PonchoTA79400 | Engine | 3 | 03-13-2004 09:25 AM |
