thats awesome learn something new every day! I really dont know what I am doing building a motor. I just want to know how bad enough I am putting most of my money into this and hope it works with you guys and my machinist's advice I just hope it all works and if not I will learn what i did wrong when I have to tear it apart and fix it Im not good at learning by reading I have to be hands on and I appreciate all the help
When you get your engine dialed in and tuned right, you will likely see the stall is much closer than it is now! |
that was with my stall in a th350 and a 355 with flat tops and some stock fuelie heads with 1.94 1.60 a preformer rpm intake and a summit 234-244 488-510 that truck weighed 3650 and was slow as hell I hated it after all the work I did to it. when I got it all it had was the flat tops and heads I put the rest of it on the motor and it only picked up one tenth
Yer in for some fun, now! |
I met some older guys last night that are local drag racers here that say they will show me the ropes and want me to race my truck I also found a 67 nova for sale today for 1500$ I think I might go buy so not its wether I want to put my motor in my truck or in this nova I know the nova will get alot better traction versus the truck and be lots faster but the truck is what I have been working on for long time now hard choice
are you using a roller cam? if not, you don't need a wear plate or a button.
And if you are using a roller cam, then you need to check the endplay of the button to the timing chain cover. furthermore, a regular timing chain cover isn't really stiff enough to hold a roller cam in place |
hey tech I am looking into buying rods and a crank havent really looked at any cranks yet but I was looking at some rods that were decent price they were eagle F5 05 0540 are those any good what I would like to be able to do is spin my motor 8k without worrying I know that is out of my power band but I want it tougher than what it needs to be so any advice on a crank and rods if those rods arent good enough
got my rockers and stud girdles today (finally) so I got all my parts except my thrust washer so I should have it done in a week or so wich figures cause the truck goes into paint friday or saturday I still gotta pull the tranny out cause there is a broken bolt that holds the filter up I gotta retrieve and replace but its getting there slowly but surely oh yeah I also bought that demon 750 double pump manual secondaries and one more thing I downloaded this comp cams cam quest thing it is basically a dyno simulator and it helps pick out a cam and it picks out a cam one size smaller than what I went with but it says 569-hp and 550-tq that is saying that i have high performance heads but I dont know if that is accurate what do you think would you say performer rpm heads are high performance
| horsepower?? any guesses | 327supreme | Hotrodding Basics | 12 | 03-24-2009 09:32 PM |
| Build for Hp or Torque? | Venturat | Engine | 76 | 09-23-2008 10:22 AM |
| Horsepower & Performance Formulas/Calculators | edge | General Rodding Tech | 7 | 08-13-2005 06:01 AM |
| ???the 411 on HP now & then ??? | Rob Keller | General Rodding Tech | 20 | 07-13-2005 06:00 AM |
| Horsepower.... and horsepower loss | PonchoTA79400 | Engine | 3 | 03-13-2004 09:25 AM |
