I am new to this site I am building a sbc 409 (.040 over 400) Im kinda new to the engine building I would love to put it on a dyno but just cant justify spending 400 on somebody else tuning my motor and knowing how much horsepower it makes anyway this is what I got and please bare with me I dont know all my part numbers
holley street avenger (670?)
ported edelbrock performer rpm heads stock valves 64cc chambers
holley strip dominator intake
speed pro forged pistons -4cc dish = 11-1 cr
solid roller comp xr 292
in a 509 400 block
stock polished and shot peened rods (5.7)
stock crank
anyway what do you think for hp and torque I know some of you guys are real good at this and I know everyone thinks that theyr motor makes way more than it does so dont hold back
Can't help with Hp but give the guys some time. You posted at midnight and 12 hrs later want answers. Hey the west coast guys are probably just on their second cup of coffee and the east guys are on lunch. Have patience and I am sure someone will chime in with some figures.
I calculate 11.3:1 cr for your setup, which is a little high. I think you will need to run 93 octane and retard timing a little. 10.75 or even 11:1 would be better.
but I would say 500/530 ftlbs if the engine is assembled and tuned correctly. Heads are most likely holding you back, but will make extra low rpm torque for the street.
I really wanted it to make good torque cause my pick up weighs about 3700 with me in it I have messed with alot of old bottom ends you know putting cams in changing heads and junk like that but this is my first real build up and I have been told that I should hit the 500 hp mark but wanted second opinions thanks I appreciate your guesses
It would be worth it to have the heads cut to 2.055 intake valves if you have the cash, the 400 needs air like it was a small big block. IMO the 670 carb is too small, even for a torque motor, so don't worry too much about torque because the 400 will have it anyway. Way, way more than a 350. Intake is a good choice, cam is also. STUD THE MAINS, ARP bolts in the rods, Stud Girdle on the rocker arm studs. 1-3/4" headers best but 1-5/8" will work nearly as good, get what will clear the angle plugs.
I've built several nearly identical versions of this combo, you could easily see 540+hp if the heads are good. Believe me, once you mash the gas on this, you will never look at a 350 the same way again.
EDIT: Compression ratio is a little stout for pump gas unless you stay on top of the tune and ignition advance curve. If you want to take some away, open up the combustion chambers some to the bore outline around the intake valve, curving over to the spark plug.
I don't want to open a can of worms here but some 400 4-bolt blocks have had issues w/main webs breaking when stressed.
I believe the reason that Chevy went to a 2-bolt later on was due to this- they found better reliability from it, rather than the 4-bolt configuration. If you look closely at the 4-bolt web, you can see how the bolt "holes" it.
A better scheme is to use a 2-bolt and splayed caps if you don't go w/an aftermarket or bowtie block, IMHO.
I know others swear by the 4-bolt blocks, and have had great luck w/them, and I have absolutely no prob. w/that.
Cobalt is right about the weakness of the 4-bolt 400 and why Chevy went to 2-bolt, and it is why the smart racers don't go looking for a 4-bolt 400. That being said, there aren't 400 blocks on every street corner and so we have to run with what we have. I've run 4-bolt 400's at this power level without a failure but it was not by choice. Getting up over 500hp in a stock block of any brand is always a gamble, that's why Dart is doing good business.
hey guys I sold my 4 bolt 511 block to help fund this build but the 509 block is a two bolt main im sure excited all i have left to buy is push rods and guide stud girdles and everybody I have talked to around here (my machinist) has told me I need to run some race gas to accomodate for my high compression wich I am ok with I dont plan to drive this truck as a daily driver and thanks so much for your guys input and now you got me thinking to take my heads off to have new 2.05 intakes in do you know if 2.08 would fit performer rpm heads my dad always told me it was better on 400s to run the biggest you could on the intake valve side it sucks not having him around to ask these ?s
Personally, I really like dbl. pumpers/ mechanical secondary carbs. For your deal, at least a 750.
While larger valves can be worth some power, if I were to have wanted 2.08's say, I'd have bought different heads (Dart, etc.) with a larger port and combustion chamber volume than the RPM's.
This starts a never ending cycle- at some point you have to commit to a build, optimize the components, buy them and build.
If you keep changing your mind (I know how this works ain: ) the costs and complexity keep rising.
Were it me- and I had amassed the parts that you have, and given the weight of the truck- I think I'd go ahead with the build as-is. But a different set of heads sure would be nice... and then I could use different pistons, and gears, and then...
very true thats how this build got started I had a all stock 511 400 in it and I wanted to change cams and then I thought well I could go with a better cam if I can find some decent 64cc heads so I had it down to a short block then I thought well Ill just pull it out and check the rods and mains make sure they are nice and then they werent so it was a complete rebuild then I found a 509 block a better crank I found my heads for 500 complete rebuilt with all port work already done and had some 5.7 rods laying around already shot peened and polished and I had the forged pistons with them and all of a sudden I didnt use a single part of the original motor thats what I hate about tearing stuff apart it always costs you money
The 780 carb is a better choice than the 670, and I have good success with vacuum secondaries, but you need to know how to tune the accellerator pump and the vacuum secondary spring, otherwise a DoublePumper is more fool-proof. If the heads are already on the motor, I'll agree with run them as is, you could always pull them for a valve size upgrade next winter if you find you want to look for more power at that point in time.
I have prolly 20 holley 4 barrel carbs I know I could put together a double pumper or 4 just need to know what to use as for part #s on what body and everything my dad was awesome with all this but he past away and I have no one to learn from now so I resort to the computer for my info
First, I sympathize with you on the loss of your Dad, It's tough. I know.
One choice would be a 4779 Holley, number found on the choke air horn. Double pumper mech. 2'ndaries, 750 cfm.
I would start with the jetting that came in it- I don't have my Holley book in front of me ATM, but can find the stock specs if you don't find them elsewhere. Power valve depends on your manifold vacuum. Start w/a 65 and go down if needed.
just out of curiousity prolly not much difference in expensive stud girdles and cheap ones right? I know because I AM running sollid roller I should run them especially with 3/8 screw in studs I should run them so would some cheap summit ones be ok or tell me why I should run more spendy girldles
as stated previously, i feel that a 750 (4779) will give you at least 10 maybe 15 to 20 more hp. as for the heads, i feel in stock form they are limited to maybe 440 hp, so whatever port work is done will determine hp output. i haven't seen any dyno tests on these heads with a roller cam, maybe someone here has. my guess is about 475 hp, with ALOT of torque. if the heads are better than i believe, you could see 500hp (jmo).
4779 jetting is 70 or 71, front, and 80 rear. the older ones had 70 in front, the newer ones, around 4779-5 and up had 71 in front. all but one came with 80 in the rear. i've found stock holley jetting is usually very close.
I am gonna buy some new rocker arms this week should I run a 1.6 on exhaust side or 1.6 all the way around or just 1.5s and thanks guys really appreciate the help and advice guys
thats awsome thanks for doing that tech inspector I was hoping somebody would do that what program do you use to dyno the engines like that and where do I buy it
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
