horsepower and torque - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2011, 08:43 PM
I am restoring 1955 chevy, pulling out the original 265 and replacing it with a 350. I do not want to overkill on power but I do want something mild to medium.
recommendations on HP and torque
Old 04-21-2011, 09:02 PM
350 Sbc
Take a look at the Chevy crate motors. Best bang for the buck. Several HP levels available.
Ron
Old 04-21-2011, 10:41 PM
techinspector1's Avatar
Wiki Edits: 326
I might be thinkin' 375-400 horsepower, 425+ lbs/ft of torque with 9.0:1 static compression ratio, stock converter, mild cam (204-212 intake duration @0.050", 110 LSA), RPM intake, 750 carb, 1 5/8" long-tube headers and 3.50 rear gear. Just a real nice cruiser. I really, really like these heads. They're inexpensive and they work. This is for one bare head....
http://www.competitionproducts.com/R...info/RHS12407/
Then buy one valve kit (fills 2 heads)...
http://www.competitionproducts.com/H...ductinfo/8511/
One guide plate kit (fills 2 heads)...
http://www.competitionproducts.com/M...tinfo/42151-8/
And one rocker stud kit (fills 2 heads)....
http://www.competitionproducts.com/A...info/134-7101/
Here's the cam...
http://www.summitracing.com/parts/HRS-110315-10/
or here...
http://www.competitionproducts.com/H...nfo/110315-10/
And here are the roller lifters...
http://www.summitracing.com/parts/HRS-91164N/
or here...
http://www.competitionproducts.com/H...uctinfo/91164/
Use a Howards composite distributor gear (will outlast a bronze gear 3 to 1)...
http://www.competitionproducts.com/H...uctinfo/94402/
RPM HP TQ
2000 148 390
2500 188 395
3000 238 417
3500 292 439
4000 342 449
4500 379 442
5000 401 421
5500 400 382
6000 355 310
Cam installed retarded 2 degrees.
Old 04-22-2011, 06:02 PM
Horsepower and torque
We're just about finished building a 350 SBC using the 170cc RHS cast iron head. The intake flows well after a little work (265cfm @ ).600") but the short turn on the exhaust had to be modified. If I remember the exhaust flowed about 210cfm after we worked on the short turn.
This engine will be a "mule" motor to go on the dyno for R&D purposes.
Are the HP & TQ figures from the engine described here?
Ron
Old 04-22-2011, 06:47 PM
Onefunponcho's Avatar
techinspector1 thats a great build
Pontiac like TQ numbers and with the low rpm powerband and stock converter.
Thanks for sharing
horsepower and torque help schottout Hotrodding Basics 3 09-29-2009 12:34 PM
Horsepower Vs. Torque automods General Rodding Tech 16 12-14-2008 10:02 PM
torque and horsepower americanLT1 Engine 1 02-19-2007 11:39 AM
How much horsepower and torque? 85montehotrod Engine 21 09-06-2006 03:28 PM
How much horsepower and torque you think i have? RiceMuncherdude Engine 15 03-13-2003 07:25 AM
