Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Horsepower/torque from 327 engine build??
Old 02-07-2005, 04:56 PM
J327HO J327HO is offline
Thumbs up Horsepower/torque from 327 engine build??
"sorry about putting this in someone elses thread,I am ...
hello and my brother are having a 67' 327 built's whats going into it...
small journal steel crank checked,polished - .10 undersized
stock rods from 67' 327
clevette77 ' H ' series rod & main bearings
ALL ARP bolts & studs *every bolt inside and out*
speed pro power forged aluminum pistons (10.35 comp. ratio )
childs&albert dura-moly rings
TCI rattler dampener *balancer*
Crane Cams blue racer double roller timing set
Herbert solid lifter cam - .518/.536 lift - dur.- 280-288 ...
herbert solid lifters
Herbert swedged end (.080" wall ) 1 piece pushrods
World Sportsman 2 64cc Heads - straight plug - 2.02/1.60 valves
Comp Cams magnum roller rockers - 1.5 ratio
Fel-pro gaskets used except head gaskets
SCE pro copper head gaskets .032" thick
melling high volume oil pump - & Melling pump shaft
Herbert extra capacity (7 qt.) oil pan & pickup
MSD pro billet distributer with vacuum advance - & 6T box,etc
MSD 8.5 wires
Edelbrock Victor Jr. (1" taller) aluminum single plane intake
Edelbrock performer 750 carburetor
Edelbrock performer 110 gph fuel pump & Herbert pump pushrod
... anyways ...if im missing something just tell me,lol... what would the horsepower potential be for this setup we're doing here??? the block work was donr by Jungle, it is .60 over ...everything was checked,crank is great! ...anyways,like to know the power potential we'll have with this... Thanks!!!
oh,we might go with a Holley street avenger 770 carb,just depends....and the engine is going to be balanced by a race shop close to here....everyone swears by them and there work.. so..
cam specs -
RPM range - 2500-7000
int.-Dur.-exh. - 280...288
int.-.050-exh. - 244..252
int.-lift-exh. - .518/.536
Lash-lobe C - .024- 106c
