Horsepower/torque from 327 engine build?? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-07-2005, 06:09 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
I think that if driveability is of little concern and a 3000-3500 stall with a 3.73 or lower gear it will be a good combo even with pump gas...assuming that the cam has a tight lobe sep, which you did not post.. Do you have the lobe seperation by chance?
  #17 (permalink)
Old 02-07-2005, 06:13 PM
lobe seperation?? ...
I got a cam sheet here for it but dont see anything about it....lol,sorry I sound alittle stupid...
  #18 (permalink)
Old 02-07-2005, 06:14 PM
OddRodder's Avatar
CORNFED and INBRED !?!
LSA, I think that you stated it at 106
  #19 (permalink)
Old 02-07-2005, 06:17 PM
Originally posted by OddRodder
O.K.! Your combination should make between 1.1 and 1.2 H.P. per cubic inch. Try to get as close to 4000 stall in a GOOD converter as you can afford (get a big trans, cooler as well)! Run a rear gear in the range of 4.10 to 4.30 and try to keep the car as light as possible!! Let Her Rip!!!!
But a nice 700 dbl.pumper!!!
I swear that I didn't see your post before I wrote this, Firestone!!
hey hey hey! ....okay!!! thanks!!!will consider all!!!!
yea...you can tell im only 16...didnt even know I wrote it already,lol
  #20 (permalink)
Old 02-07-2005, 06:21 PM
OddRodder's Avatar
yea...you can tell im only 16... [/B][/QUOTE]
Yeah, Me Too Kid!!!!.......At Heart, where it counts!!!
  #21 (permalink)
Old 02-07-2005, 06:26 PM
Yeah, Me Too Kid!!!!.......At Heart, where it counts!!! [/B][/QUOTE]
LOL....
  #22 (permalink)
Old 02-07-2005, 06:28 PM
NXS's Avatar
NXS NXS is offline
A 106 lobe seperation would be great for a 10.5 pump gas engine but i think that was lobe centerline listed?
  #23 (permalink)
Old 02-07-2005, 06:44 PM
lash-Lobe c?? ... .024-106c
In the doug herbert catalog and onthe cam spec sheet it says " rough idle,moderate performance usage,good mid-range HP,increased comp. ratio advised,great for short oval tracks or stock weight drag cars"
...and someone mentioned to me that this was the biggest cam I could have without having to get a stall or I could get away with a 2500-3000 stall...??
  #24 (permalink)
Old 02-07-2005, 07:20 PM
NXS's Avatar
NXS NXS is offline
Ok, i re-read. OP said 106 C and Oddrodder said 106 lobe sep!
Your lobe sep determines how power is distributed in the rpm range. A tight sep makes for a less efficient engine with power being concentrated in the mid and mid-upper rpm ranges. It will allow for more compression as it bleed off pressure from valve overlap.
A wide lobe sep on the other hand is more efficient but builds a lot of cylinder pressure and is better suited for lower compression daily drivers (or highway rockets). They will provide a smoother idle with more initial response and more topend power but will result in lower peak numbers due to their wide power band.
  #25 (permalink)
Old 02-07-2005, 07:33 PM
OddRodder's Avatar
Hey NXS, your graph is a comparion of say a 106 to 112 LSA? It leaves a little to the imagination! I tried to watch your rainy day video a while ago but it wouldn't load for some reason? Think I'll go try again!!
  #26 (permalink)
Old 02-07-2005, 07:47 PM
NXS's Avatar
NXS NXS is offline
Well the graph may not be that great, but the vid should load. Keep in mind this is a V6 with welded spiders. I held it kind of straight until the end. It got a bit sideways just before it stopped spinning. I figure that sign is about 1/8 mile from my driveway.
So, will that block work for you? I hope so b/c that was a long ways to drive for a cracked block, lol!
  #27 (permalink)
Old 02-07-2005, 07:54 PM
OddRodder's Avatar
Yeah, I'm sure I can use it. I found a pretty bad crack in a different cylinder than the one we were lookin' at! Hope it doesn't take 2 sleeves!! I'll try to get a pic. of it in a minute or two! Checked out the video tried to make out the roadsign three or four times, I think I could read 412.
  #28 (permalink)
Old 02-07-2005, 09:06 PM
Hey!! ...how about this...
Weiand stealth aluminum intake - power range - idle-6,800
& a holley 670 street avenger ...
OR Weiand team G power ram intake - power range - 2,800-7,200 ... and a classic holley 700 double pumper...would these help out for alittle bit of street manners without sacrificing my top end around 6,500-7000RPM ??? ....
well...i've gotta altleast thank all of you for your replies,and yes they were VERY helpful to me...if anyone has anything to say or see's something *wrong* with this build,please tell me! lol....alot of money is gonna be spent on everything for this and just want it to be worth it!! THANKS AGAIN!!!
  #29 (permalink)
Old 02-07-2005, 09:40 PM
firestone's Avatar
http://teamrfc.gospelcom.net
I would actually consider the Performer RPM air gap. It is rated to 6500 RPM, but on a 327 it will probably pull close to 7000 RPM. The 700 carb sounds good. If you changed your intake, I think a 3200-3500 stall would work well. You have 200cc runner heads right?
Oddrodder, it looks like we are pretty much on the same page with this one.
Adam
  #30 (permalink)
Old 02-07-2005, 09:44 PM
1964chevelle's Avatar
its not pink its ember red
im building one also for my chevelle it is out of a 64 vette and has 461 double hump heads 234/244 .488.510 600 cfm performer carb and performer rpm intake. headers crane 1.6:1 roller rockers i was wondering what kind of power i would be making?
i also have a 3500 stall and a turbo 350 with a stage 2 shift kit...any other suggestions?
