Hose Reel Hookup - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2006, 07:55 PM
Hose Reel Hookup
I got a hose reel and have a question about hooking it up. I don't want to use hard pipe to hook it up. I want to use flexible hose between my hard lines and the reel. My question is will the fittings with the barbs to hold the hose in place be ok if I put some hose clamps around them? I probably won't ever run the regulator up over 100 psi. It's just a matter of safety because I've seen some hoses with high pressure come loose and whip around. I'd rather be safe than sorry.
Danny
Old 11-10-2006, 09:03 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
With good hose clamps it should be fine. You could always clamp you hose to the wall or whatever just to be safe from a crazy air hoses whipping around. Now me personally, I like crazy air hoses whipping around all over. It is good fun.
Old 11-11-2006, 05:04 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Been using hose clamps and barbs for years...I always use two clamps on each barb.
Old 11-11-2006, 07:19 AM
Thanks guys. I thought it would work ok but I just wanted to make sure.
Danny
What Size Air Hose are u Painting With? cab Body - Exterior 11 08-07-2006 03:48 PM
Banjo fitting illegal?? gavinpierce Hotrodding Basics 10 04-22-2006 10:08 AM
Stainless Braided Hose Sleeving Help leejoy Engine 5 04-06-2006 11:36 AM
Your not the hose? Dammit..... StrokeofGenius Engine 6 11-17-2004 11:22 AM
Lower Radiator hose Colapse?? HotRodMan Engine 4 09-06-2002 06:17 PM
