Hose from reservior to PS pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2005, 04:08 PM
guba_unus's Avatar
Learning from your mistakes
Last journal entry: CS-144 alternator
Simple question, Where do you get a hose to go from the reservoir to the pump? I checked autozone, and all they had was 5/8 heater hose. tried this and the fluid looks like its seeping through it as the hose appears wet at all times. So I need a new hose but what type do I get, cause there aren't a lot of choices in the 5/8 size?
thanks for the help
Old 08-09-2005, 04:24 PM
sedan delivery's Avatar
hose
they should have( power steering )hose. you have to ask for this type of hose . there is the return hose and a high pressure hose. heater hose is no good for this . you figured this out. try napa if they don't have it. they should have it to fit your specified car
Old 08-09-2005, 06:25 PM
5/8" power steering return line hose? I have never seen any thing over 3/8". Gas line safe hose will work fine since this is low pressure and it will resist the hydraulic fluid.
Trees
Old 08-09-2005, 06:51 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
I bought some 1/2 inch (12.5 mm) hose rated to 300 psi for just over a $1.00 a foot from autozone. I had to go to a few of them before I found one with the right hose but they do have it.
Found this on thier web site
POWERCRAFT 81352 $1.39
3/8" HIGH PERFORMANCE POWER STEERING HOSE
(CUT TO FIT) PRICED PER FOOT
POWERCRAFT 81206 $1.99
3/8" INNER DIAMETER, 300" LENGTH, 1000 PSI,
275 F OIL TEMPERATURE, CUT TO FIT 24"
POWERCRAFT 71236 LLT $10.99
3/8" INNER DIAMETER, 36" LENGTH, 1000 PSI,
POWERCRAFT 71206 LLT $21.99
3/8" INNER DIAMETER, 48" LENGTH, 1000 PSI,
POWERCRAFT 70551 LLT $7.99
CUT TO FIT
POWERCRAFT 71224 LLT $6.99
3/8" INNER DIAMETER, 24" LENGTH, 1000 PSI,
The part numbers may help
Good luck
Old 08-09-2005, 06:59 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
If there is a national or napa parts store near you..they sometimes do hydraulic hose for tractors and such and can fix one right up..
OMT
Old 08-10-2005, 07:19 PM
OMT
Exactly...about all you will be able to find that works is hydraulic hose.
If you can't find any local try www.mcmaster.com (lucky for me they are local).
Buzzin PS - Pump?? macx Suspension - Brakes - Steering 3 06-04-2005 03:06 AM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
BBC water pump bypass hose jmhollis Engine 2 06-22-2004 09:11 AM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
water pump heater hose conenction.... oldcarguy85 Engine 3 04-07-2002 09:34 AM
