Hoses, 84 mustang rack/GM Pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2008, 06:57 PM
I have read a lot of conflicting info on the installation of an 84 Mustang Power Rack with a GM pump. Could someone who has done this swap please help me out? I need the following info; Do I need to reduce the pressure from the GM pump? What is the best way to do this? Does anyone out there supply a hose kit for this installation? What are the fitting/port sizes on the Rack and also on the GM pump?
Thanks in advance, Jerry
Old 03-06-2008, 09:35 PM
powerrodsmike's Avatar
Wiki Edits: 161
Check out the tech tips from Durex power steering...Lots of your questions about fitting size and type, as well as the need to reduce pressure will be answered there.
http://www.durexpowersteering.com/techtips.html
(I've done several of these setups, and that page I linked you to gives good info.)
Many companies sell the hose kits, try Speedway motors, CPP, Heidts, Fatman Fabrications or one of the hose specialty places like Earls, Russel, or Aeroquip.
Heidts sells a pressure reduction block that you can plumb in at installation, and adjust as you see fit. They sell it with fittings to work with the braided SS hose.
All it really does is byass some of the pressure from the high pressure side hose into the return side hose. But it works.
Hope this helps,
Mikey
BE different....ACT normal.
93 Plymouth Acclaim fuel pump relay 78 monte Electrical 14 04-19-2007 03:09 PM
sbc in 84 mustang kthornhill Hotrodders' Lounge 29 05-26-2004 01:06 PM
88 Mustang Gt Fuel Pump Help 406 ss monte Engine 5 01-13-2004 01:58 PM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 12:43 PM
84 mustang front clip hapbsp Suspension - Brakes - Steering 1 12-29-2001 07:08 AM
