Hoses for a transmission cooler? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2011, 10:54 AM
I am going to re-mount a trans cooler vertically from horizontally to the front of my radiator. (TH350 behind a 350 Chevy). To do so, I will need to replace the current rubber hoses that extend from the hard lines which come as far forward as the back of my front cross-member. Should I use rubber fuel line for this? Will the Sprectre steel-braided rubber hose work? Thanks.
Old 02-06-2011, 11:07 AM
NO, you do not use fuel line. There is a special high strength transmission cooler hose. You also want to be sure there is a good nipple on the edge of the tubing you are using. If you do clamp it onto a new tubing that was cut to lenth and has no nipple using two hose clamps next to one another is a good idea.
Old 02-06-2011, 12:35 PM
sqzbox's Avatar
My pipes are my music
Using a flare tool on the line wouldn't hurt either. Just make sure to smooth the end of sharp edges or burr's.
Flexible transmission hoses insted of hard lines bb66gmc Transmission - Rearend 13 03-23-2006 04:47 PM
Transmission Cooler nova69 Transmission - Rearend 1 09-15-2003 11:56 AM
transmission oil cooler ffcagle34 Engine 5 11-22-2002 02:40 PM
transmission oil cooler ffcagle34 Transmission - Rearend 6 11-21-2002 12:27 PM
Transmission Cooler oldslane Transmission - Rearend 3 10-25-2002 11:51 AM
