Hot 388 stroker in front of stock converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2007, 08:16 PM
Hey guys I'm kinda on a budget with my car.
I just finished and fired my 388ci small block. It has a comp xe284.
For the time being since funds are tight the car has a 700r4 with a stock stall converter (from 87 camaro).
Right now I have the car idling at about 900-1000 rpm. I havent drove the vehicle yet but when I drop it into drive the rpm's drop to about 500 and the car shakes and almost stalls out.
I know this converter is wayyyy to tight however do you think it will work for a couple of months.
Is there anything I can do to better the situation?
Old 08-16-2007, 09:25 PM
runn141's Avatar
throw it nuetral everytime you come to a stop, till you get a stall converter
Old 08-18-2007, 06:54 PM
I ran that cam in a 355 and had the same problem.......you have to keep your foot on the gas while stopped........also had to ride the gas to get it to stop, only made about 8 inches of vacuum. Good luck.
Old 08-18-2007, 07:03 PM
Tyler
You better run good quality universal joints. I ran a car like that for a little while and kept busting ujoints untill I bought a set of heavy duty ones. When you put it in gear it would slam into gear. jtyler
Old 08-20-2007, 10:26 AM
Billvill's Avatar
Unless it has a monster cam or a vacuum leak you should be able to get it to hold a decent idle. If it makes good power the converter is the least of your worries. The internals of the trans just can't handle the torque a stroker makes.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Front stock shocks? mark2002 Suspension - Brakes - Steering 4 11-22-2003 09:24 PM
GM Front Diff. Reliability For Full Time Use. M&M CUSTOM Transmission - Rearend 4 10-31-2003 05:36 PM
Stock eliminator 78 monte Engine 5 01-02-2003 05:10 AM
what's the largest cam i can run with a stock converter? COCHEV Engine 24 11-29-2002 04:54 PM
