hot air always - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2008, 05:17 AM
New Member
hot air always
I have 97 Ranger that blows hot air cannot adjust temp. looked in haynes repair manual nothing,any ideas?
Old 06-08-2008, 08:43 AM
Most likely the flap control is broken, not sure if yours is cable operated or vacuum though. Turn the switch to cold/ hot and see if you hear any change. If not pull out the control or feel in behind and see which it is. The cables break or pop off an end sometimes.
Old 06-08-2008, 09:26 AM
Or as a TEMPORARY FIX ... you can install a cut - of valve in the heater hose line and stop the flow of coolant into the heater core.
Old 06-08-2008, 01:12 PM
New Member
hot air all the time
thanks for the info will check this out,looks like a real time consuming job.
Old 06-08-2008, 02:31 PM
41willys's Avatar
Blowin' it
Last journal entry: Running again...
Wiki Edits: 11
When you say hot air, do you mean heater or ambient outside air?
Jason
Old 06-08-2008, 03:01 PM
If you are talking about A/C... check the temperature of the larger diameter line. It should be cold with the a/c on.(about 33- 40f). if it is than your heater valve is letting hot air flow it the plenum. you can temporaily check that by pinching off your heater hose to the heater core.
If the a/c line is not cool your a/c is not working for some other reason. (ie.low refrigerant charge, bad fuse, bad clutch or comperssor)
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
one giant orange peel flamedfordbronco Body - Exterior 14 06-20-2007 09:04 PM
Fresh air respirators 2stroketurbo Body - Exterior 26 02-15-2007 06:41 PM
Just hot air trainmanbr549 General Rodding Tech 4 07-16-2005 12:06 AM
K&N air filters may void warrantees. Jmark Engine 0 05-05-2004 10:40 PM
