hot air intake - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2005, 06:44 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
hot air intake
I've got a carbed '87 mustang that I'm planning on driving through this winter to work every day. It currently has an open element air cleaner on a holley 650DP carb. I know from the factory most carbed cars had a stove off a manifold to provide warm air until the engine got good and hot. I'm thinking of making a duct to send hot air from my headers to my air cleaner... would it be ok to run the hot air pernamently until springtime? Would this help with driveability and fuel economy?
Russel
Old 11-06-2005, 07:56 PM
BOBCRMAN@aol.com's Avatar
I have always made my hot air (winter setup) from a closed side air cleaner (duct tape and light cardboard around an open side filter in one case). Then run VW beatle style aluminum flex tubing to a fabricated small box mounted over the center exhaust header tubes, close to the head.
This has saved my donkey a few times in the fall when the humidity gets to be about 90+ percent and the temp gets down to low-mid thirties.
Without it carburetors torn into large snowballs. The throttle plates freeze solid and you slowly choke a rich engine that won't shut off. Then dumps large amounts of water into the intake when it thaws.
Old 11-07-2005, 03:19 AM
aka Duke of URL
This earlier 5.0L setup will give you heated and outside cool air.
ID:	7715   Click image for larger version
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
shooting clear vinvango73 Body - Exterior 3 10-29-2005 12:24 AM
Cold air intake for a carb Jag Daddy Engine 6 01-15-2005 05:21 AM
is a h20 fueled engine possible spinn Engine 55 11-26-2004 11:52 AM
